They work
I figured they would since its the same company that makes the 63 gram lifters I currently sell on the store. Didn't notice any difference in ticking or sound or anything compared to the other lifters but for the weight savings I think its a nicer upgrade. I will add them to the store soon, pricing will be 350 for the set of 24 vs 300 for the 63 gram lifters. Stock lifters are 77.1 grams (all weights as empty).
I also found some valve springs but have to get new seats to fit. They are 125# at valve seat vs 80# for stock (65# in 96), and 198# at max lift for stock cams vs 180# for stock (160# in 96). I think GM went with lighter springs due to smaller lifters being used, and probably also as a physical rev limiter though I have no proof of this. Anyway, I haven't priced a set of springs yet nor ran them to see how they work, but wanted to throw this in since thats the latest on what ive been up to. Oh, and the new springs will allow for .400 lift with plenty of room before coil bind. Probably a bit stiff for NA but I think boosted applications will find a use. With stock cams, you can fit a .015, .030 or .060 shim under them to make them stiffer. Ill be selling these shims on the store soon as well, $24 for a set of 24. Ill include all the spring specs using shims as well so you know what you are going to end up with using the shims.
I figured they would since its the same company that makes the 63 gram lifters I currently sell on the store. Didn't notice any difference in ticking or sound or anything compared to the other lifters but for the weight savings I think its a nicer upgrade. I will add them to the store soon, pricing will be 350 for the set of 24 vs 300 for the 63 gram lifters. Stock lifters are 77.1 grams (all weights as empty).I also found some valve springs but have to get new seats to fit. They are 125# at valve seat vs 80# for stock (65# in 96), and 198# at max lift for stock cams vs 180# for stock (160# in 96). I think GM went with lighter springs due to smaller lifters being used, and probably also as a physical rev limiter though I have no proof of this. Anyway, I haven't priced a set of springs yet nor ran them to see how they work, but wanted to throw this in since thats the latest on what ive been up to. Oh, and the new springs will allow for .400 lift with plenty of room before coil bind. Probably a bit stiff for NA but I think boosted applications will find a use. With stock cams, you can fit a .015, .030 or .060 shim under them to make them stiffer. Ill be selling these shims on the store soon as well, $24 for a set of 24. Ill include all the spring specs using shims as well so you know what you are going to end up with using the shims.
