96-97 48 gram lifters????
  • your_I.D.
    • Mar 2005
    • 337
    Anyone found lighter lifters for the 96-97 motors?
    UPDATE Found 53 gram 33mm lifters!
    Factory lifters weight: 62 grams
    1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
    1972 3/4 ton 4X4 longbed, built 350, 400 auto, 6\" spring lift, 35\" AT/BFG\'s, dana 60 front axle, 14 bolt gm w/detroit locker 4.56 gears. My ricer smasher
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    RE: 96-97 48 gram lifters????
    96 motors use the same lifters as 91-95
    • your_I.D.
      • Mar 2005
      • 337
      ok my bad then 97 motors. the smaller lifter design.
      • series8217
        • Dec 2004
        • 387
        Anyone have pics of the 97 cams and cam carriers?
          • 13528
          I found another 33mm lifter but I need a stocker to compare with. I doubt its lighter though.
          • your_I.D.
            • Mar 2005
            • 337
            I found some aftermarket ones. I ordered 3. I'll compare the weights Friday.
            I can take some tonight.
            • series8217
              • Dec 2004
              • 387
              That'd be great, thanks.
              • series8217
                • Dec 2004
                • 387
                Piiiiicsss?
                • your_I.D.
                  • Mar 2005
                  • 337
                  series8217
                  • series8217
                    • Dec 2004
                    • 387
                    Awesome. Thank you very much!
                    • series8217
                      • Dec 2004
                      • 387
                      They did nothing to fix the horrible oil drainback. Interesting. All the same tiny passages and casting flaws I had to fix when I built my 93.
                      Anyone have pics of the oil distribution cover for the 97? I wonder if the passages are smaller to restrict flow to the heads.
                      • DreX
                        • Nov 2003
                        • 74
                        Did you weigth the lifters? That will give a ball park#
                        Thanks
                        DreX
                        • your_I.D.
                          • Mar 2005
                          • 337
                          Factory 97 33mm lifters weight: 62 grams dry
                          Aftermarket 97 33mm lifter weights:53 grams dry
