Direction flow question
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    If you have a set of heads that you are porting the exhaust to and want to mate up a manifold to the exhaust in the best way possible for flow direction purposes, should you angle the port upward, downward, or straight off that port? This would be for a couple of different heads, but we'll use the lx9 3500 as an example.
    I am thinking for stock heads it would be best to come straight off of and if ported, angle upward a few degrees (nothing drastic) .
    Is this correct logic based on the design? Will there be a common thing to note/look for in making this decision?
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    nada?
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      really depends pn the shape of the port, if it approaches the flange at an angle, then angled, if straight, then straight.
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        3500 looks like it approaches it at an upward angle.
          • 13513
          It doesnt.
            You aren't going to gain anything by angling the port shape in the direction of flow for a manifold. Just clean it up and polish the crap out of it.
            Headers man... manifolds suck.
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              Headers should still be provided the best initial direction of flow to enhance there efficiency
                With headers you don't have pulses from other ports interfering with the flow though.
                When you build the headers you would follow the angle of the port out for a little bit before changing direction. Doesn't have to be much but you don't want to turn it right at the flange. Makes for a bad hot spot and will fry header coatings plus not good for flow.
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  When you build the headers you would follow the angle of the port out for a little bit before changing direction..
                  And that is exactly what got this thread to be created!
                    • 13513
Name:	20140625_122654 (Medium).jpg
                    WOT-Tech port mold of the 3500 exhaust.
                    • 1988GTU
                      LB62LHObbqftmfw
                      • Nov 2005
                      • 2475
                      Untouched port correct?
                        • 13513
                        Correct.
