turbo 1998 monte carlo
  • xspsi4
    • 7
    had a brainsyorm today want to turbo my 1998 monte carlo. i have a turbo from a 1990 toyota supra laying around and i know that i can mount it but i was wondering what this would do to the computer and sensors? and do i need bigger injectors and can the mass air sensor be in line with boost going through it ? how much boost can i run (6-8 psi) where do i get extra fuel? would an apex-i piggyback fuel comp work i am trying to do all this 4 under 250. any help would be greatly app. thanks
  • bwawuz02
    • 52
    first of all what motor is in ur car, and secondly, it shouldn't be that hard, i believe you're on the right track because someone has successfully done it that way using a GM mini-AFC, i wouldn't try going over 6psi or so. and you'll need a dyno to tune it.
    93 Z34 Auto (old, dead, slow, in peices)
    91 GTP 5spd (older, faster, better)
    • brian89gp
      • 554
      3100 engine I assume? Being OBD2 I'm not sure how well the PCM will handle it, its picky about those sorts of things.
      • Cliff8928
        • 532
        I'm not sure that a Toyota CT-26 turbo is exactly the best thing to attach to a 3100.... I heard that they are fairly limited..
        Cliff Scott
        89 BerettaGT
        89 Volvo740
        Cliff Scott
        89 BerettaGT
        04 AleroGX
        • xspsi4
          • 7
          Cliff Scott
          89 BerettaGT
          89 Volvo740
          thanks 4 the help turbo is on and goeing it ran a 15.2 in the quarter not to bad. with the addition of an intercooler if i am lucky and on a cold day it might hit 14.9 boost is set at 6.5 psi all i really needed was a pressure regulator air fuel is where it should be
          • nocutt
            • 123
            You are kidding right
            3800 S3 intercooled turbo...
            • Anonymous
              Pics.
              • Manitcor
                • 573
                WTF, that was fast
                1995 Monte Carlo LS
                3400 SFI 60v6
                • Anonymous
                  13 days later and he has a turbo....
                  • nocutt
                    • 123
                    Oh I C...I think he meant he had the turbo in the car...(like passenger seat or something) and then went to the track...
                    • brian89gp
                      • 554
                      the CT-26 stock will do about 350hp.
                      • Anonymous
                        A N/A 3100 W-Body running a 15.2 would be a miracle of god.
                          • 13530
                          just about. baby jesus might have a hand in that as well.
                          • Cliff8928
                            • 532
                            Do they have different versions of the CT-26? (maybe i'm thinking of the one from the 3S-GTE).. i heard they were not the best in producing the boost..
                            Cliff Scott
                            89 BerettaGT
                            89 Volvo740
                            Cliff Scott
                            89 BerettaGT
                            04 AleroGX
                            • Anonymous
                              3100 > DOHC, and we all know it.
