turbo 1998 monte carlo
  • nocutt
    • 123
    Originally posted by Cliff8928
    Originally posted by brian89gp
    the CT-26 stock will do about 350hp.
    Do they have different versions of the CT-26? (maybe i'm thinking of the one from the 3S-GTE).. i heard they were not the best in producing the boost..
    Depends...they really cannot handle consistent moderate to high boost due to their ceramic compressor wheel...they basically tend to shatter!!
    3800 S3 intercooled turbo...
    • brian89gp
      • 554
      The ceramic turbine wheel is a J-Spec thing as far as i know, mine has a steel wheel.
      There are various versions of the CT-26. There is the Supra one which is a single 2.5" inlet and 4 bolt downpipe flange. I believe this is the largest and oldest of the turbo's, it originally came on a 3.0L DOHC and boosted to 12psi if i remember right. Then there is the other version, split inlet and a 6 bolt downpipe flange, this was orininally on a 4cyl motor.
      From what i have found the Supra CT-26 is roughly equilivent to a mid sized Garret T3. They can be upgraded to support around 600hp but for the cost you might as well use a Garrett turbo.
      • Cliff8928
        • 532
        ... and that 4-cyl motor would be the 3S-GTE The one you have came from a 7M-GTE
        Cliff Scott
        89 BerettaGT
        89 Volvo740
        Cliff Scott
        89 BerettaGT
        04 AleroGX
        • brian89gp
          • 554
          ah, ok. You are right, the 4cyl one would probably be too small for a v6.
          • 3100rettaracer
            • Nov 2003
            • 70
            hey do me a fav. post some pics. i wanna "boost" my beretta so showing your exhaust manifold setup would help
            i swear...if one more person asks me how to open the fricken doors on my beretta......
            95 Beretta (red)
            3100 v6 58mm TB, K&N cone filter, dual exhaust. in the midst of rennovation (turbocharging & 5speed swap)
            • brian89gp
              • 554
              #21
              www.brian89gp.com they are in there somewhere
              And I have a 3.4 DOHC so all I had to do is flip over a front manifold and put it on the rear, impossible to do on the pushrod motors.
              • 3100rettaracer
                • Nov 2003
                • 70
                #22
                hrm...well. thanks anyways... btw what will that gtp run??? it looks like it would be a fun to drive
                95 Beretta (red)
                • xspsi4
                  • 7
                  #23
                  the supra turbo ct-26 is what i used the car has now been sold but it ran great boost was awesome trans went out though. i guess no one apprecieates the work that went in 2 this car the gm community has not responded very well 2 this and people here are basically calling me a liar. this was my daily driver my other car is a porsche 944 turbo with tons of mods and my baby is my galant vr4. i am now working on a 96 gtp i am goeing 2 turbo it with the same ct-26.if any one has any input get at me.
                  • xspsi4
                    • 7
                    #24
                    if u spend youre time thinking that a 15.2 is fast then something is wrong with youre thinking, that sucks royal ass. it is a sad thing 2 think people are hopeing 2 run 15s 14s or even 13s. gm sucks from a engineering standpoint, i know where there is street driven eclipses running 8s from 2 liters of displacement. all i have 2 say is 2 valve pushrod technology was cool 60 years ago.
                    • skalor
                      • Nov 2003
                      • 95
                      #25
                      Yeah, a 15.2 is not exactly fast. I've run a 14.6 in my TGP on 11psi with basically no other mods, and that's a 3,390 lbs car without me in it.
                      If you think that GM cars has no engineering in them, have you ever even looked at an eclipse. 4G63s are a horrible engines to actually work on and I have seen way too many unmodded ones blow-up none-the-less modded ones. I prefer the SR20DET over the 4G63, it's a much better design in my opinion and it has a timing chain over the crappy timing belt. I helped my friend put a U13 DET into his '91 sentra se-r a couple years ago. He runs a 13.6 @106 on only 7.5 psi and that's on a T-25!!!
                      \'89 Ciera Int. Coupe
                      \'89 TGP
                        • 13525
                        #26
                        I like my belt, thanks.
                        • patgizz
                          The Plaid Bandit
                          • 1071
                          #27
                          = "i never turbo'd my monte i'm just a troll who thinks he is cool by playing 'i have a 600hp chat room racer'"
                          • LukeZ34
                            • 30
                            #28
                            People are calling Bullshit on you because you never produced any pictures of the work. You have all the money own those nice cars, and to do all this turbo work, but you can't buy a simple $100 digital camera to take pictures and SHARE with us what you have done? Makes no sense to me.
                            1996 Grand Prix GTP Special Edition - Coilovers & ST springs, magnaflow exhaust, M&S FWI, Powrtuned ECM, Aweb Door sills, much much more.
                            1987 Suzuki Samurai JX Tintop - Weber DGV5E carb, 2" exhaust, Calmini Header, 147k, daily driver
                            • xspsi4
                              • 7
                              #29
                              what are you smoking. you guys all need to go back to school. i would take the 4g63 over the sr20det anyday. if you dont believe me about the 8 second talon go to shepracing.com and look at that daily driver. you all just need to go import and leave the pushrod technology along. i have a race for you guys, your fully modded V6 against my moped. I work at a GM dealership and I work your shit all day long.
                              • jmgtp
                                • 1219
                                #30
                                Well this is a GM 60v6 board. Get the fuck out.
                                I feel bad for GM customers that have assholes like you working on their car.
                                I'll take the race against your moped, lets put some money on it... seems like your just some chat room racer, I bet the moped is your only ride.
                                1994 Corvette
                                LT1/ZF6
                                2006 Dodge Dakota 4x4
                                3.7/42RLE
