WOT-Tech needs 10mm 3400 heads
    • 13499
    No cracks, and id like pics. I could get them from car-part but I know people on the forums have heads and I have been asked before when I have plenty or there is no demand. Well, I need a set asap, and id consider buying 2 sets. I am willing to spend 100 a set plus shipping, and I am not going to be stingy on shipping when I want them to be safe from damage in transit.
    Thanks!
  • robert 1980
    • Aug 2009
    • 302
    Should have taken mine....they were sweet
    • geldartb
      The Situation
      • May 2004
      • 1994
      i still got my old set and maybe one more.. definitely know 1 is 10mm the other i'm pretty sure is but i'd have to check.
      i can grab some pics on thurday if that's fine.
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
        • 13499
        Im hoping to get a set here by Friday but if that doesn't happen, then it doesn't happen.
        • bob442
          Show Me Your KITS!
          • Nov 2008
          • 1305
          Why not drill and tap them? It way to easy with the heads not installed, and cutting them with a tap leaves them with a bit more meat on the threads than how the factory does it.
          • NateD4
            • Mar 2011
            • 576
            What are 10mm 3400 heads?
            I may have a set if you still need them.
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              10mm rocker threads I assume.
                pre 2003 3400 heads IIRC.
                  • 13499
                  I should have 1 set on their way here right now, and would like 1 more if geldartb has a set there. Any more than that and I can only offer store credit. If that is of interest to anyone that has 10mm rocker arm 3400 heads (170 or 487), shoot me a PM. I would like to pay for heads once they arrive so that I can clean them up and verify they aren't cracked. Credit would be given in the form of a coupon code.
                  • geldartb
                    The Situation
                    • May 2004
                    • 1994
                    i'll snap pics of what i got today.
                    10218170 are the heads i got. send you pics later. do you need the springs and stuff. these are still assembled minus the rocker arms. i should still have those somewhere or do you just want the bare heads.
                    99 Grand Am GT
                    • NateD4
                      • Mar 2011
                      • 576
                      Would you take a set or two of 3400 heads for store credit on porting a set of 3900 heads?
                        • 13499
                        Towards port work, sure no problem. What kind of porting, and would you want valve job/milling as well? We can take care of that when you are ready if not right away.
                          • 13499
Name:	IMG_0201 (Custom).JPG
ID:	377308Click image for larger version
Name:	IMG_0200 (Custom).JPG
                          Just got these in the mail, both with cracks between the spark plug hole and intake valve seat. I can't tell you how many times I have had this happen so please look at your heads closely.
                            far too common with 3400 heads...
                            I haven't seen it myself but do the 3500 heads have this same issue?
                              • 13499
                              I haven't seen any yet for the 3500 heads. Not sure if its metallurgy or design though.
