3500 injectors
    Live life 3.7mi at a time
    • 4555
    3500 injectors
    I know the plug is different from the earlier injectors, but are they the same impedence? I would like to make an adapter plug for them to work on my hybrid, but didn't have my meter at the shop today to test.
    • 13531
    Yup, same resistance as the other stock 60V6 injectors.
      • 4555
      Thanks. So my harness adapter should be an easy deal, then.
        • 13531
        What are you doing, adapting the 3500 injector harness to something else? That is what I have to do once I get my wiring harness.
          • 4555
          Yes. I want to make a pigtail basically. Actually, then I would have to find a bunch of chassis-side connectors from 3500's. Probably just re-pin the stock conncetors from a Gen1. This way the rail will plug in like it would stock.
          Do you know what pressure and lbs they were rated?
            • 13531
            24# @ 55psi is what I have read. Maybe be in the delphi site but I didn't look.
