I know the plug is different from the earlier injectors, but are they the same impedence? I would like to make an adapter plug for them to work on my hybrid, but didn't have my meter at the shop today to test.
3500 injectors
Tags: None
Thanks. So my harness adapter should be an easy deal, then.Originally posted by SappySE107 View PostYup, same resistance as the other stock 60V6 injectors.
What are you doing, adapting the 3500 injector harness to something else? That is what I have to do once I get my wiring harness.Ben
Yes. I want to make a pigtail basically. Actually, then I would have to find a bunch of chassis-side connectors from 3500's. Probably just re-pin the stock conncetors from a Gen1. This way the rail will plug in like it would stock.Originally posted by SappySE107 View PostWhat are you doing, adapting the 3500 injector harness to something else? That is what I have to do once I get my wiring harness.
Do you know what pressure and lbs they were rated?
24# @ 55psi is what I have read. Maybe be in the delphi site but I didn't look.Ben
