How to convert to Pre-94 OBD I ???
  • TheDirtyBen
    • Mar 2004
    • 130
    i have a 94 Olds Achieva w/2002 3100SFI, 4T60-E tranny, ABS, Airbag.
    1)What yr/make/model do i need to find an ECM from?
    2)will i need different harness connectors?
    3)does anyone have wiring diagrams?
    4)am i forgetting anything?
    1994 Oldsmobile Achieva (2002 3100 SFI)
    Homemade ram-effect CAI
    K&N cylinder filter
    Poorboy Lowering Kit
    Front STB
    • 13534
    Im guessing a 94/95 DOHC computer is your best bet if you want to retain SFI, trans controls, and tunability. If you aren't MAF now, it would be with that setup. ECM connectors definetly changed. There is a 94 lumina in the junkyard here in warsaw, complete as of a few months ago (doubt there is much desire from anyone in this area for the engine either).
    • TheDirtyBen
      • Mar 2004
      • 130
      so, 94/95 3.4 DOHC has the MAF setup? or is it a combo MAP/MAF? Do you have a ECM ID# ? can you call your junkyard........see if they still have it,price? i'd assume i'll need the engine harness as well.
      K&N cylinder filter
      Front STB
        • 13534
        Im not awake when they are open:P They wanted 30 bucks for a 3.1 wiring harness, but you have to pull it yourself. They want 50 for the ECM.
        • Robb235
          • Jul 2004
          • 78
          http://www.car-part.com will prolly help you find any parts that you're looking for. :-)
          1995 Monte Carlo LS
          • TheDirtyBen
            • Mar 2004
            • 130
            yeah, but their prices are whack!!
            K&N cylinder filter
            Front STB
              • 9191
              I started a how-to article awhile back... I'll let you look at what I got done...
              http://60degreev6.com/SwapGuides/PCM...ade%20Swap.doc
              • TheDirtyBen
                • Mar 2004
                • 130
                awesome!! will the DOHC ECM run my car until i have it re-programmed?
                K&N cylinder filter
                Front STB
                  • 9191
                  You need a 3.1MPFI chip, but it will get it running.
                  • TheDirtyBen
                    • Mar 2004
                    • 130
                    so, i can't use the 3.4 DOHC for reprogramming?
                    K&N cylinder filter
                    Front STB
                      • 9191
                      A DOHC chip won't run an MPFI/SFI engine AFAIK. The computer will work, just need to plug in a MPFI PROM.
                        • 13534
                        well im confused now. are you running SFI or MPFI? 94 DOHC was SFI and MAF, so you would just need to run the MAF. I have no idea how well it will like running the stock code. the 93 stock DOHC code will run a 3100 but it wont be optimal, or even close, but it runs.
                        • TheDirtyBen
                          • Mar 2004
                          • 130
                          ok, so which is it???
                          K&N cylinder filter
                          Front STB
                            • 13534
                            fuck if I know, its up to you, not me. I would use the 94-95 3.4 DOHC setup and just use the 94-95 DOHC MAF sensor with it. Then reprogram it. That way the trans will be no issue at all, and you can change the shift points as well. Granted I have no idea how much of the DOHC code has been decoded...but I know the engine can be tuned if nothing else.
                            • TheDirtyBen
                              • Mar 2004
                              • 130
                              any updates? is the DOHC code decoded yet? Ugh! I haven't even gottem started on this project yet (money issues).
                              K&N cylinder filter
                              Front STB
