computer chip for 3.1 v6
  • Andy
    • Oct 2005
    • 14
    i have a beretta with a 3.1 v6 and im getting ready to put a cam in it but i need to get a computer chip to put more fuel into the motor so the cam works right so if anyone knows about a chip then contact me. thanks
    • 13525
    RE: computer chip for 3.1 v6
    Which cam are you putting in there and what other mods?
    • Andy
      • Oct 2005
      • 14
      ROUGH IDLE, PERFORMANCE USAGE, GOOD MID AND UPPER RPM TORQUE AND HP, 3800-4200 CRUISE RPM, 10.5 TO 12.0 COMPRESSION RATIO ADVISED. BASIC RPM 3800-7200 its a crane cam and im also getting some valve springs
        • 13525
        Which crane cam is that and are you raising your compression?
          • 13525
          Nevermind, I found it. Solid cam, so I can't really help you with a chip unless you can get the car to me. No one has a chip burned for that cam that I am aware of.
          • Andy
            • Oct 2005
            • 14
            i live in richmond,in what would be a good performance cam for a 3.1 that you have a chip for
              • 13525
              Well, it would be best if you can get the car to me regardless, but the crane 260 cam is one that I have tuned with some other mods. I can setup a chip to work pretty well without the car using that cam. I would raise the compression some as well if you are getting new pistons.
              • Andy
                • Oct 2005
                • 14
                what would be the pricing on all of this like for the cam, valve springs, computer chip, and pistons. and is there any way that i could just put a cam, valve springs and a chip in it without getting new pistons and raising the compression
                  • 13525
                  pistons vary on price but install is gonna cost a lot more than the pistons if you dont do the labor yourself. I don't know what cams cost these days but you will need a set of lifters to go with the cam. Chip is 125, valve springs should be around 80 plus shipping. Custom tuning is 125-350 depending on mods but with just a cam, the tuning wont take much time to figure out. Dyno time for dyno tuning however increases the price quite a bit.
                  • Andy
                    • Oct 2005
                    • 14
                    i think im just gonna forget about the cam. but do you know about a good chip that i dont have to get anything else with it i can just plug it in.
                      • 13525
                      http://60degreev6.com/store/index.ph...b6d125562c8c1c
                      • Andy
                        • Oct 2005
                        • 14
                        what's the difference between the L body and the J body. and does this remove the rev limiter
                          • 13525
                          L body is beretta, J body is Cavalier. Sure, I can remove the rev limiter but I don't recommend it.
                          • Andy
                            • Oct 2005
                            • 14
                            do you work at 60degreev6
                              • 13525
                              im the owner:P I run the 60v6 store and my own company, wide open throttle technologies. I used to do chips for FDP and FFP, but now I sell them myself through this site.
