Wideband Logging; was Tunerpro RT datalog aldl def
  • ryan.hess
    • 526
    I know freescan r0xxorz your b0xxorz and all, but has anyone created a ALDL definition file for any 60* v6?
    I'm looking into building wideband logging capability with the 7730. There are a couple unused inputs, and it seems like it would be only a little work to port a 5V input to the ALDL output.
    But, the problem is freescan doesn't let you change their ALDL definition. So, that's why I'm asking.....
    Okay now, that's enough of that.
  • Mars
    • Apr 2004
    • 826
    That would be the coolest thing evar...
    Which inputs arent used?
    I have always used Datamaster to datalog, I am running out of trials...heh.
    I'll try out Tunerpro ASAP (when the snows gone)...
    • ryan.hess
      • 526
      Lots. Pins A3 (TPS2), B3 (MAT2), F14 (MAP2), E10 (MAT3) to name a few.
      I'm not sure about the last 2, but for sure the first 2.
      I've already found out how to read the value, I just need to find a place in RAM to store it, and then modify the code to spit out the value as part of the ALDL communications.
      Then, you've got an extra 0-5v input you can datalog along with everything else...
      If somebody has the ALDL datastream mapped for Tunerpro RT (free software), then it would be just a simple case of adding a new value... Unfortunately I don't even know where to start there.
      • SHOoff
        • Jul 2005
        • 356
        Is it that the inputs are unused? Or is it that they're unused on only a particular type of car. (I.E. F-body may use more sensors than a J-body will) Maybe it's already part of the datastream is what i'm saying.
        97 Cavalier RS
        3400, Isuzu MK7
        • ryan.hess
          • 526
          Those are inputs GM didn't use on any of our cars. Go figure, who needs 2 MAP or MAT sensors? They were left in for upgradeability no doubt.
          Also a google search turned up 3400beretta has the file I need... just sitting in limbo for now.
          • Mars
            • Apr 2004
            • 826
            You can go and ask right at the source, there is a Tunerpro forum online someplace, the owner, Mark M. should be able to guide you in the right direction.
            • ryan.hess
              • 526
              Got it. I'll work on putting out a patch.
              • Mars
                • Apr 2004
                • 826
                Email me whatever that other dudes sends you, if you don't mind.
                marcelbrosseau at hotmail.com
                Thanks!
                • ryan.hess
                  • 526
                  Done. I'd like to see it hosted here as well, it stores more information than freescan could dream of... Imagine having a datalog, where you could read how far you've traveled in miles...
                  • Mars
                    • Apr 2004
                    • 826
                    If you make any headway on the WB thing, you let me know.
                    I am working on one for the tgp version (2 bar map)... not as easy as one would think, but it is possible.
                      • 13525
                      I didnt think the RT version was free though.
                      • Mars
                        • Apr 2004
                        • 826
                        Hell ya it's free.
                        • ryan.hess
                          • 526
                          That's what I thought... then everyone was like "you need to try this!"
                          It has a 10 second "register me" wait time when you start it up, but it's free!
                          • ryan.hess
                            • 526
                            I'm 90% there to testing... I'm having a problem with the assembler not labeling my new subroutine. Once I get that figured out, I'll run a test in the driveway...
                            It's not that bad, I went from almost no assembly or ECM programming knowledge, to writing patches in assembly for binaries in a week :P
                            I'll keep everyone posted... it should be easily portable to most 1227730 v6 binaries.
                            • ryan.hess
                              • 526
                              IT WORKS!
                              At least in the driveway it works. I need to confirm that it still works with the engine running, but it should, because I put the call to the program where it checks the narrowband o2 sensor... And obviously that works with the engine running... :P
