parameters to change injector size
  • berry
    • Nov 2012
    • 22
    Hi guys
    Which parameters (names) do I need to change, when I've replaced the fuel injectors with lager ones?
    I know low and high slope, fuel breakpoint and Injector Offset.
    But what are the exact names in the XDF-file (A1)? I have troubles to find them.
    Thanks for your help.
    My Car: 1992 Beretta 3.1 MPFI, auto
    ...cruising around...
    92 Chevrolet Beretta GT V6 3.1 MFPI auto 30K white
  • berry
    • Nov 2012
    • 22
    Is there anybody out there?
    • young gun
      • Jul 2010
      • 250
      I'm sure someone will chime in soonish. Just a tad bit slower around here these days.
      • young gun
        • Jul 2010
        • 250
        SappySE107
          • 13496
          BPC vs EGR is the main one for fuel constant.
          • berry
            • Nov 2012
            • 22
            Thanks Sappy. But I can't find BPC vs EGR in the strategy A1. Maybe the name altered?
            • berry
              • Nov 2012
              • 22
              ah you mean the table Base Pulse Constant vs Desired EGR (F28 ) ?
              • berry
                • Nov 2012
                • 22
                Why EGR? EGR sounds in this combination very confusing. Does it play a role if I already deleted the EGR?
                  • 13496
                  its a base pulse constant vs EGR%. If you delete the EGR, then use the 0% (top) number only. Im not sure what the table label is.
                  • berry
                    • Nov 2012
                    • 22
                    It sounds logical. I will do.
                    • berry
                      • Nov 2012
                      • 22
                      I've found it! See picture below.
                      Sappy, you've said that BPC vs EGR is the MAIN one for fuel constant. Does this imply other secondary parameters I need to change?
                        • 13496
                        SImply put, thats it. If you want to tweak something else, offset vs battery voltage would be the next one that comes to mind.
                        • berry
                          • Nov 2012
                          • 22
                          thanks!
                          • berry
                            • Nov 2012
                            • 22
                            btw Sappy,
                            CONSTANT = 1461.5 * (EGR FACTOR)(LITERS/CYL)/(INJECTOR RATE)
                            did you make the math to work meanwhile?
                            you wrote at:
                            10-17-2011, 08:09 PM
                            1461.5 * (.988 )(.516)/(2.09) = 0.152
                            That makes more sense other than I still can't make it work as a math formula either.
                            source:
                            so, when I take for the EGR Factor 0.000424 it seems to work:
                            ​​​​​​​CONSTANT = 1461.5 * 0.000424 * 0.516/2.09=0.153
                            is that right?
                              • 13496
                              It worked for me once and that was it. What size injectors and its a 3.1?
