Reading/ Reflashing 29F chips - electrical gurus?
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    I have written a scan tool for GM as well, includes most special functions like CKP Variation relearn that most do not have
    May or may not come to light, but I am enjoying trying.
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
      • 13530
      no hardware needed but a cable to usb/serial?
      • Weatheralls Auto
        • Dec 2009
        • 536
        Must have hardware to interpret the J1850 Protocol.
        Scanner right now works with any Elm device, which is basically a $20 to $40 device.
        I am def not putting any one or any device down.
        Just trying to create alternatives.
        As of April 2
        Injectors: #36 GTPs
        TB: 65mm TCE
        • dimented24x7
          • Jan 2010
          • 22
          From what you can tell? Unless you work for HPT, I think you are making this up.
          Im not saying they get ALL of their info from the manufacturers. They have a lot of smart guys working over there. But, from the internal documentation that I have from GM, the wording and naming of various calibration terms by them and GM is consistent, at least for the earlier LS1 stuff. I dont have anything personal against them, but it does suggest that they (and others) are privy to a lot of info from the manufacturers. To turn around and charge for it is a bit of a grey area in my book.
          • dimented24x7
            • Jan 2010
            • 22
            Originally posted by planethax View Post
            2 per vin for 60*V6 etc, 4 for others like LS1 I believe for HPT.
            So some will be $160, not saying one program is better than the other, just that it seems expensive.
            This is why I am trying to make an alternative, may not be as easy or efficient as HPT or even DHP, but more for the DIY.
            If I can make an Open Source alternative for $100 - $150, if it takes longer or is not as efficient, I think it will not only benefit the community but force the others to lower their prices? would you not agree?
            This is what Ive been working towards as well. The info is out there to do fully functional DIY tuning and flashing. Its just a matter of pulling it all together. I know that programs like TunerPro work well to tune the PCM. Ive used it to tune my vortec PCM. Just need the info to construct the definitions and the hardware/interface to do the reflashing. The hardest part is the definitions. I did the vortec PCM from scrach, and that was a pretty challenging task to map it out just by examining the hardware and code.
              • 13530
              #21
              How do you think any of us could do OBD1? You can say what you want, but if there is demand, there will be people selling a product. You are ignoring a huge investment in time to make use of that information to benefit from that code. I would guess you are from the DIYEFI group, as they share that point of view.
              Perhaps I should give away my porting secrets. I didn't cast the heads, so who am I to make money on modifying them.
              • Weatheralls Auto
                • Dec 2009
                • 536
                #22
                Def not what I am saying.
                They have hard work involved and can sell it for what they want.
                I too will have alot of work involved, and it will be my choice to give it away.
                Reading back on the history of early OBD2, there were many sharing info, only some are receiving the money for the efforts.
                I am willing to do as much work as I can and encourage anyone/everyone to help.
                Just like it is fair and free enterprise to sell something there is a demand for, it is the same for competition to keep prices in check.
                In no way I think I will every be inline or comparable to HPT or DHP unless there are others to help, but some sort of competition or alternative is always good.
                IMHO that is what both the US and Canada have been built on.
                As of April 2
                Injectors: #36 GTPs
                TB: 65mm TCE
                  • 13530
                  #23
                  i was talking to dimented actually.
                  • dimented24x7
                    • Jan 2010
                    • 22
                    #24
                    Thats a rather broad sweeping statement on what I believe, based on an observation that I made.
                    Many of these companies started out as a few DIYers, who, once they have the information they need, shut the door, put out their shingle, and set up shop. Many companies have started this way, and its not really fair to those who where kind enough to give some of these people the info they needed, only to have it used for profit. If you dont believe me, see HP-Tuners archives. Once they had the basis down for how to reflash the PCMs, the exchange of information ceased.
                    As for the info obtained from the manufacturers. If its leaked, then really its not their intellectual property. That would be kind of like a company in China stealing the plans for a Boeing 777, and manufacturing it as their own. Now, obviously its up to the auto companies to take any action. But, without that info, there would be a lot less support from the for-profit guys then there is now. The bulk of the needed work is in the info on the PCMs. That information is very hard to get just by reverse engineering alone. I can state that from experience. To get the calibration information by those means alone would at least take an order of magnitude more man hours than whats put into the software package development.
                    Anyway, I digress...
                    • Weatheralls Auto
                      • Dec 2009
                      • 536
                      #25
                      I have read through the entire available archives at HPT (and more) and I mean every post.
                      I have seen first hand what dimented is saying, he was one of many who shared his info.
                      That has been a long played out situation that is like beating a dead horse.
                      That is why,in my opinion, it is better to move forward and try to create an alternative than dwell on it.
                      I and others who are helping are just trying to help the community.
                      As of April 2
                      Injectors: #36 GTPs
                      TB: 65mm TCE
                      • dimented24x7
                        • Jan 2010
                        • 22
                        #26
                        And the problems that stem from that are when the efforts are made by DIYers, that are then used by others for profit. For a while, that sort of thing just KILLED the DIY community. Thats not just biting the hand that feeds you, its chopping it off, grinding it up, and selling it as fish bait.
                        More generally, I for one like having alternatives, and like the free information exchange. It makes things not only cheaper, but much more interesting when you can get involved yourself as opposed to having to pay someone else to do it.
                        • dimented24x7
                          • Jan 2010
                          • 22
                          #27
                          Thats my feeling as well. Its a lot of sour grapes with some of the others, but if we dont share, then theres no community. So its a risk worth taking IMO.
                            • 13530
                            #28
                            So I was correct with my observation. I shared the info I had (the A1 and DF files), which was given to me by someone else, who was given the info from someone else. It was my choice to share it with the internet. Imagine how much of the market I could have cornered in time had I not done so. I learned a lot though, and whlie I have DIYers competing with me, it is the time that I have put into tuning that makes the difference. Dave knows well enough how that works
                            I refuse to read HPT forums. I have no idea who to believe, and so I will skip the bullshit and learn from what I know from my OBD1 experience. It does not surprise me with what is being said, but it doesn't help me any. I started a business because I wanted to do this for a living. If you do not want to have others use your information, don't share it. As such, I do not post my porting secrets. I don't know what to tell you.
                            • dimented24x7
                              • Jan 2010
                              • 22
                              #29
                              Insofar as observing that someone your talking to in the US might be an American. I dont necessarily hold all the same views as others.
                              My main point is that its dishonest and underhanded to take someone elses information given with the intent of it being for the general community's free use and using it for profit. If everyone does this, then the information just wont be there one day. I think it would be a fair statement to say that at least some of the OBD-I information that you built your buisness and knowledge base on came from the DIY community, no?
                              With that in mind, can you see how some people might be just a little irritated?
                              • dimented24x7
                                • Jan 2010
                                • 22
                                #30
                                And this is why people sharing information is so important. Knowledge is what allows you to sort out all the BS from the meaningful stuff. Selfish pilfering is what squelches that knowledge.
