Initial scan, hunting idle
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    3500 using 3400 Pcm and GTP injectors (flow rate 220)
    Idle is hunt a bit 25 to 50 Rpm, worse the lower the idle.
    I used Tech2 and idle smooths out after 1100 commanded Rpm.
    Checked for Vac leaks, none.
    here is a quick scan at Operating temp.
    edit, should also mention that this is a Manual trans.
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    • 13533
    fueling is off. I don't know if 220 is right or not as DHP is different values than HPT.
    • Weatheralls Auto
      • Dec 2009
      • 536
      What tells you my fueling is off?
      My AFPR from TCE doesnt seem to be working correctly, pressure is @ 55psi with or without vacuum.
      This is how I came with my IFR for injectors
      using GTP injectors
      Stock injectors for the 3400 were 22.5 @ 55psi
      Gtp are 36 @ 50psi
      stock IFR for the 3400 with 22.5 @ 55psi is 371
      by staying with the Stock 55psi they would flow 37.7571
      So 22.5/37.7571 = .5959 * stock 371 IFR, new IFR would be 221.
      As of April 2
      Injectors: #36 GTPs
      TB: 65mm TCE
        • 13533
        That is odd that it doesn't change pressure with vacuum.
        What PSI are those injectors at for their 36# rating? your LTFT tells me your fueling is off.
        • Weatheralls Auto
          • Dec 2009
          • 536
          the 36# were at 50psi, so I converted that to 55psi they would flow 37.7571
          Something really off with the afpr, if I lower the psi below 50 the Vacuum seems to change the pressure,
          As of April 2
          Injectors: #36 GTPs
          TB: 65mm TCE
            • 13533
            Might be because its based on a stock regulator and they wouldn't increase above 50 based on vacuum alone.
            • Weatheralls Auto
              • Dec 2009
              • 536
              May have to get a stock fpr and recheck, then if it works better, transfer the TCE cap over.
              You think this would cause the idle hunt?
              Basically a Stock 3400 tune except for Injector flow rate and some DTCs, I am just starting out the tune.
              Engine went in this weekend.
              3rd Gen Cavalier
              As of April 2
              Injectors: #36 GTPs
              TB: 65mm TCE
              • Weatheralls Auto
                • Dec 2009
                • 536
                Any tips?
                Wideband bung should be here this morning, and replacing fuel filter as well.
                Not sure if I am trusting my HO2s currently.
                If it is doesn't corelate with the WB I will replace it.
                Not much tuning done at all, but this is what I have to work with.
                Quck initial test drive.
                As of April 2
                Injectors: #36 GTPs
                TB: 65mm TCE
                  • 13533
                  why are you going full throttle on something you haven't hardly tuned?
                  • Weatheralls Auto
                    • Dec 2009
                    • 536
                    Just that one test, just to see what I am up against lol,
                    since it was a stock 3500 running stock 3400 code, was hoping it would be a little closer.
                    As of April 2
                    Injectors: #36 GTPs
                    TB: 65mm TCE
                    • Weatheralls Auto
                      • Dec 2009
                      • 536
                      So, except for not going WOT lol, any other tips.
                      Hope to get some time tomorrow for some tuning.
                      As of April 2
                      Injectors: #36 GTPs
                      TB: 65mm TCE
                      • Weatheralls Auto
                        • Dec 2009
                        • 536
                        Just starting my VE tune now, having problems with the Table Modifier though.
                        I follow the book, when I try to import my new VE table it fails because it is missing variables ?
                        Scan http://www.scandepot.net/viewscan.php?pk=5042
                        Original VE Table http://www.scandepot.net/viewscan.php?pk=5044
                        Modified VE Table from Table Modifier http://www.scandepot.net/viewscan.php?pk=5043
                        What am I doing wrong?
                        As of April 2
                        Injectors: #36 GTPs
                        TB: 65mm TCE
                        • Weatheralls Auto
                          • Dec 2009
                          • 536
                          Ahhh, Set KPA range in table modifier
                          As of April 2
                          Injectors: #36 GTPs
                          TB: 65mm TCE
                          • CNCguy
                            Bisong eater :P
                            • 1017
                            Rob,
                            What did you find out about your fuel pressure? The pressure should change with vacuum unless the spring is bottomed out. Can you adjust the pressure higher?
                            MinusOne - 3100 - 4T60E
                            '79 MGB - LZ9 - T5
                            http://www.tcemotorsports.com
                            • Weatheralls Auto
                              • Dec 2009
                              • 536
                              It was acting really funny, but I knew my Fuel Filter was probably plugged as when I replaced the pump 2 weeks ago it was siezed on.
                              I had let it sit and soak and have finally replaced it.
                              Pressure does seem drop a very tiny bit with vacuum, but not much.
                              I have been busy at work and not had a chance to get to it again.
                              This one was the complete unit, what Base do you use? pre 2000 ? or newer?
                              I was thinking of getting a new 2000+ base (55psi) and try that.
                              As of April 2
                              Injectors: #36 GTPs
                              TB: 65mm TCE
