Initial scan, hunting idle
  • CNCguy
    Bisong eater :P
    • 1017
    We use new 00+ Delco regulators to insure long life. That's why I was wondering what was going on.
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
    • 86FieroSEv6
      • Feb 2010
      • 527
      Damn if that doesn't look like a leaking or weepy injector . . . . .
        • 13533
        I use a new 94-99 base.
        • Weatheralls Auto
          Spinning out of control
          • Dec 2009
          • 536
          Hmm, very possible, I really expected to see this run lean but it seems to be rich.
          The Racetronix Walbro pump doesnt have a check valve so pressure leaks down as soon as pumps turned off,
          think I will pull the rail and check for leaks next.
          As of April 2
          Engine: 2006 SV6 3500 LX9
          Trans: 2002 Getrag F23 5speed
          Injectors: #36 GTPs
          TB: 65mm TCE
          Maf: 1999 3400 Montana.
          Beverages: Ice Cold CANADIAN.
          • Weatheralls Auto
            • Dec 2009
            • 536
            checked injectors, none weeping and balance test is good.
            Still, Vaccum does not change fuel pressure, and when shutting off I loose pressure instantly.
            If I pinch return line Pressure holds. Looks like a bad FPR, went to order a new delco today to check, Canadian price is $112, nuts!!!!!!!!!!
            And our dollar is above par right now.
            As of April 2
            Injectors: #36 GTPs
            TB: 65mm TCE
            • CNCguy
              Bisong eater :P
              • 1017
              #21
              Double ouch... so much for the Delco regulators being the best choice for reliability. And that price sucks as you can get one here for about half of that.
              '79 MGB - LZ9 - T5
                • 13533
                #22
                If it holds vacuum, its not a bad FPR. Try tuning it instead.
                • Weatheralls Auto
                  • Dec 2009
                  • 536
                  #23
                  Tuning? I do not see how that will effect my fuel pressure lol.
                  The AFPR does not hold vacuum, or my Vacuum pump is leaking.
                  I do have it working better now, I removed the screw completely, and started engine.
                  about 23 psi, when shut off it held the 23 psi as well.
                  as soon as I started to adjust the screw pressure dropped to 0 (not running)
                  Started back up without vacuum and set to 55 psi, plug in vacuum line and it dropped to 44 psi.
                  So this part is now working, thinking maybe plunger was jammed somehow and this straightened it out?
                  However, as soon as I shut off vehicle, pressure drops to 0. If I pinch return line it holds so the regulator is not holding the pressure
                  when shut off.
                  Is this just a characteristic of these I have to live with? (which I can) or is it faulty?
                  As of April 2
                  Injectors: #36 GTPs
                  TB: 65mm TCE
                    • 13533
                    #24
                    I didn't say it would affect your fuel pressure. I said the fuel pressure is not causing your idle RPM problem (with it not changing on vacuum). The regulator has nothing to do with the fuel pressure dropping on key off. That is your fuel pump/check valve. Tuning would solve ALL your problems, but I am not going to keep telling you this. You can replace parts until the tune falls in line I guess, if that ever happens.
                    • Weatheralls Auto
                      • Dec 2009
                      • 536
                      #25
                      I understand now you mean tune for hunting idle. (should have started new thread I guess)
                      However, it would be pointless to tune with the incorrect pressure, would it not?
                      I now have the correct pressure so tuning is next step. ( I was tuning and getting very rich reading, now seems to be much more stable)
                      I initially thought the fuel pressure dropping off was the check valve in the pump (or lack there of) however, why would pressure hold if I pinch the return line? or if I lower pressure by removing the screw?
                      I am not replacing parts, tuning would only mask a fuel pressure problem would it not?
                      As of April 2
                      Injectors: #36 GTPs
                      TB: 65mm TCE
                      • Weatheralls Auto
                        • Dec 2009
                        • 536
                        #26
                        Oh, I should add the hunting idle is also now gone.
                        As of April 2
                        Injectors: #36 GTPs
                        TB: 65mm TCE
                          • 13533
                          #27
                          With a sealed system, you can only vent to the tank and the return. Like putting a straw in a glass, putting your finger over the top, and pulling it out. No leaks, till you release the top.
                          You are talking about a pressure that is set at idle and increases slightly with higher loads. Not all systems use this so you can most certainly tune with static or rising rate fuel pressure. It is when the pressure drops from a clogged filter or faulty pump that you cannot tune it.
                          • 86FieroSEv6
                            • Feb 2010
                            • 527
                            #28
                            Dude, that is a bogus regulator. I'd cut a few lawns for the money to replace it.
                            • Weatheralls Auto
                              • Dec 2009
                              • 536
                              #29
                              To let EVERYONE know though, Mark at TCE saw this thread and immediately said he would replace it.
                              I was not 100% sure if it was causing an issue so I was still testing.
                              TCE stands by their product for sure. I dont want to have him ship me a knew one if its not an issue.
                              Sappy, that make sence about the straw, just curious on why it would hold pressure if I remove the set screw completely?
                              Think I may just get a new one test it and see, then put the TCE cap on.
                              As of April 2
                              Injectors: #36 GTPs
                              TB: 65mm TCE
                              • Weatheralls Auto
                                • Dec 2009
                                • 536
                                #30
                                Well I got around to putting a Stock 43.5 psi regulator on today, fuel pressure now holds when vehicle shut off.
                                So as I suspected this was causing my headaches.
                                I took it one step at a time as so much was done at one time,
                                2.4 to 3500 engine, Stock to Racetronix fuel pump etc etc so wanted to verify.
                                As of April 2
                                Injectors: #36 GTPs
                                TB: 65mm TCE
