front sump oil pans
  • spike
    • Jun 2009
    • 2
    front sump oil pans
    Wondering if anyone knows of a stock front sump oil pan that will fit a 93 3.4 out of a camaro. Maybe a front wheel drive engine? Thanks
    • 13528
    You would have to make one as I have not seen anything like this. What are you swapping the motor into that you would need this?
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Agreed you would have to make one. You would also need to make a corresponding pickup. A 3800 (gasp) will have a central pickup which might make your job a little easier. No GM engine I can think of had a front pickup or front sump pan.
      Even front mounted oil pump engines like the Buicks and Cadillac V8 had rear sump pans.
      • spike
        • Jun 2009
        • 2
        front sump oilpans
        Would anyone know how many different oil pans would fit a 93 3.4 and how different they are from each other. (just making sure I check all the options)Thanks
        • geoffinbc
          • 5831
          You can use a 2.8L S-10 Pan which comes in 4WD or 2WD versions. You can use any Gen I and II FWD 2.8L, 3.1L or 3.4L DOHC Pan. If you have a good idea of what you want I would go to the junkyard and check some pans out. DON'T FORGET to get the pickup tube for the oil pump!
