3500 (LX9) swap into a Fiero
  • flimbob
    • Jan 2010
    • 73
    #91
    That would be great if you could. Either way I'm in.
      • 13524
      #92
      Done. Login is your new email and I emailed the password to you.
      • flimbob
        • Jan 2010
        • 73
        #93
        Thanks
          • 13524
          #94
          Sweet it worked Did you have it tuned with the auto already?
          • flimbob
            • Jan 2010
            • 73
            #95
            No, went straight to getrag. The 4t60 ended up in another car.
            • flimbob
              • Jan 2010
              • 73
              #96
              Looks like my throttle body shaft has play, causing TPS issues. Need to verify WOT-TECH store has a 65mm throttle body in stock.....
                • 13524
                #97
                I sold the rest of what I had over the break but already have more on the way. I have one I took apart because the linkage is broken that might work for you. You would have to swap your current shaft, which shouldn't have any wear because it goes into roller bearings. That would be my guess for your issue anyway. If you want to try this one, I can give you a deal on it. Otherwise it will probably be a couple weeks before I have more cleaned up and ready to use.
                • flimbob
                  • Jan 2010
                  • 73
                  #98
                  Already ordered before I read your post. What would you want for the broken one?
