3900 into 2005 subaru legacy AWD
  • farmerz24
    • Feb 2004
    • 361
    #61
    The hole I need to enclose
    Custom trans mount
    Underside of car
    • young gun
      • Jul 2010
      • 250
      #62
      Awesome! Good thing subies have hood scoops stock
      • Guest
        #63
        Sweet.
        • farmerz24
          • Feb 2004
          • 361
          #64
          Boom
          Hood scoop fitted
            Should do it like an evo hood rather than directing all the water right at the engine and belt assy...
            • farmerz24
              • Feb 2004
              • 361
              #66
              • geldartb
                The Situation
                • May 2004
                • 1994
                #67
                if you haven't welded that scoop in flip it around and see how it looks. will probably work better than the way you have it setup now. the way it is now any precipitation and potential debris will head right towards the manifold.
                99 Grand Am GT
                1357 cam 227 233 .050 dur
                515 515 lift 112 lsa
                • caffeine
                  • Jan 2012
                  • 1489
                  #68
                  That scoop is very stock-style except a bit farther forward. I think it suits the car but there has to be a way to prevent rain/dirt from getting through.
                  '86 Fiero, 3500, 4-speed
                  • Guest
                    #69
                    Don't like it... Probably mostly because of angular it is, and not rounded like the car.
                    I've been trying to think of something for a while on how I would dress this, and haven't come up with anything I really like, or can easily explain. But the best idea I've had so far, I think is to use a stock scoop, or possibly an STI scoop, because they are taller, and then mount it in front of the intake, and then blending it into the hood, with smooth transitions, probably out to existing body lines to keep it subtle.
                    • farmerz24
                      • Feb 2004
                      • 361
                      #70
                      Modified front cover with rad cap and alternator mount.
                      Almost ready to run it up to temp with working accessories.
                      • farmerz24
                        • Feb 2004
                        • 361
                        #71
                        Idle vid
                        • young gun
                          • Jul 2010
                          • 250
                          #72
                          Whats left? I see a bunch of wiring just laying on the intake manifold lol
                          • farmerz24
                            • Feb 2004
                            • 361
                            #73
                            a few things.
                            got my tach to work with the ms3x. this involved a tinyio board from jbperf.com.
                            it communicates to the ms3x-pro via can to get the rpm. then outputs a spoofed 36-2-2-2 wheel pattern for the stock subaru crank trigger to work. this allows my tach to work and the fuel pump to run. excellent.
                            also did a test rip. needs a tune.
                            • 34blazer
                              • Sep 2007
                              • 341
                              #74
                              Cool!
                              '86 Grand National
                              • young gun
                                • Jul 2010
                                • 250
                                #75
                                Good stuff! I love that you can keep the stock gauges
