3900 into 2005 subaru legacy AWD
  • farmerz24
    • Feb 2004
    • 361
    #76
    With paint
    • geldartb
      The Situation
      • May 2004
      • 1994
      #77
      looks good. personally i would have went for more rounded edges but if it works then i probably wouldn't have screwed with it anymore... how's it drive.
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
      • unchained01
        • Jan 2011
        • 388
        #78
        great job !!!
        • farmerz24
          • Feb 2004
          • 361
          #79
          Eventually I plan to relocate the front ps resivoir and rad fill spout, this will allow me to use the factory hood scoop and will look much more "stock"
          Regarding driving, it needs tuning. Definitely more low end tq right now below 2000 than the stock motor.
          Also when I made the transmission mount I mounted it solidly to the transmission but used bushings where it connects to the body. I may need softer bushings as well as adding another one where I connected directly metal to metal. When driving around 50mph it has a loud resonance within the cabin. It could also be my rear driveshaft angles are not correct. Noises are definitely louder when accelerating the decelerating. I had also moved the motor back an inch so the front cvs are at a different angle but I bet it is the driveshaft.
