W-Body Suspension Upgrades
This is a sticky topic.
    Originally posted by HayesPerformance View Post
    Trailing Arms:
    GM Tubular Trailing Arms #12498649
    (Comes as a pair, complete with bushings)
    (Fit 1st and 2nd Gen. W-bodies)
    I went looking for a pair of these last night and came up with the bad news that they aren't made anymore.
    I did, however, find some stock replacements made by Dorman that have 1/2" x 1/2" tube steel instead of the crappy U channel that stock uses. The Dormans do use rubber bushings though.
    I bought a set today (~$50 for the pair) and plan on removing the rubber ones and replacing them with the poly bushings in my stock ones when I start wrenching on the 92.
    I had them look up a set for a 96 Monte Z34.
      http://shop.advanceautoparts.com/web...RPCHASAMS_____
      The poly bushings for stock trailing arms DO INDEED fit the Dorman tailing arms.
      • onefastV6
        • Sep 2005
        • 880
        What poly bushings did you use in the Dorman trailing arms?
        I am debating if I should order the BMR trailing arms or if I should just get the Dorman.
        I put a addco 639 rear swaybar on the 2011 Impala and the change in handling is amazing.
        I did have to grind down the split lock retainers that attach to the bar, but otherwise a quick and clean install.
        At some point I will probably upgrade my front swaybar to the Dorman 927-100.
        I hear they are excellent quality and that they are a solid bar. It is also slightly larger than my stock front bar.
        2000 Grand Am GT
        2011 Chevy Impala
          My stock arms had bushings from RSM. I haven't installed them yet so I could measure the bushings if you like.
          • unchained01
            • Jan 2011
            • 388
            you might want to check the specs on these
            http://www.energysuspensionparts.com...sp?prod=9.9108
            these maybe very close and they come in red also
              This really isn't a suspension upgrade I found, more like a chassis upgrade. Very interesting, none the less...
Name:	lumina roll cage screenie.jpg
              • packardbell
                • Jul 2014
                • 91
                #22
                my front sway bar on the cutlass seems to have some wear, what is the best upgrade for bushing on a stocker with FE3?
                  Energy suspension greasable urethane sway bar mounts. Just be sure to grease them every year or prepare to hear them squeak over bumps when the grease runs out.
                  • packardbell
                    • Jul 2014
                    • 91
                    #24
                    I noticed when fully stopped and I turn the steering wheel full right or left there is a creaking noise. Could that be them bushing? I checked today I have some tie rod end play on the driver's side. could that make the creaking noise?
                      Sway bar bushings will only squeak with up and down travel of the suspension. When stopped the suspension is not traveling so my best guess would be strut mounts or spring bearings. Tie rod ends and ball joints do not tend to squeak. They just tend to make a knocking sound as the fit of the ball gets looser and looser in the socket.
                      • packardbell
                        • Jul 2014
                        • 91
                        #26
                        how hard is it to replace the strut mounts and strut bearings? I replaced the shocks a few years back by using the tool and just replacing the cartridge.
                          The bearings are under the springs so your front suspension comes completely apart. I bought new plates with bearings installed by Monroe from rock auto last year, haven't swapped them out, but the car is still in about 1,000 pieces.
                          • packardbell
                            • Jul 2014
                            • 91
                            #28
                            sounds like a big job to tackle to remove the driveshafts, brakes (again) to drop the lower control arm, then the strut assembly.
                              And be safe about it. Coil springs have enough energy stored in them to take your head of if you aren't careful.
