Injector flow rates - lets put something together
  • 3400beretta
    Banned
    • Jul 2005
    • 171
    Im getting sick of searching high and low for EXACT injector flow rates, I think its time we put something concrete together, and sticky it. Or better yet post it on the main page. This is what i know so far:
    1990-1994 3.1 Vin T - 16.7 lb/hr
    Multec 1 3400 - 19.?? lb/hr
    Multec 2 3400 - 22.?? lb/hr
    Please add to this, whatever you know, Im especially after the 1994-1999 3100 injector size (I think 17 something lb/hr), and the 3.4 dohc injector sizes.
    I found this website: http://users.erols.com/srweiss/tableifc.htm#ROCHESTER Lots of good info there, but almost every GM V6 is blank there.
    Make sure to list at what PSI the ratings are at too.
    • Joseph Upson
      This is the Delphi site, use the search line on the bottom right. For most of the vehicles from years back to some of the current it gives detailed specs for several sensors and parts from resistance and frequency of the knock sensor used in the TGP to fuel pump flow rate and pressure and injector flow rates also.
        • 13522
        witchhunter.com has flowed injectors and made a list.
        • 3400beretta
          Banned
          • Jul 2005
          • 171
          Where is this list? I see a few GM part numbers, 1 of which I know is a newer 3100 injector...
          • 3400beretta
            Banned
            • Jul 2005
            • 171
            http://go.delphi.com/cs/welcome.aspx
            That site has some very good info, but Im wondering how accurate it is. I checked a 1993 3.1 Vin T injector, and it says it has 15 lb/hr injectors, when I know for a fact it has 16.7 lb/hr injectors, because that is the actual value when you look at the .bin file.
              • 13522
              The 2.8 injectors are probably 15#. I have a file on my laptop with injector ratings as well. Ill put some info up on the wiki.
                Syclone/Typhoon stock injectors, 32# @ 43.5 PSI
                • 3400beretta
                  Banned
                  • Jul 2005
                  • 171
                  http://witchhunter.com/injectordata1.php4
                  Ahh, Ok, I see farther down under Rochester there is a bunch more. I'll see if I can put together something that can be put in the wiki.
                    • 9189
                    • barrok69
                      • 34
                      3400 Multech 2's are 23# injectors. Final Answer.
                      All injector info can be taken right off the Delphi website. (almost all GM vehicles use Delphi injectors)
                      -=ЯoB=- 3400 3spd Z24 ---167Hp, 193Ft-Lbs @ the wheels
                      14.99@91.33mph
                        • 13522
                        Is it? You don't think they just rounded 22.5 up?
                        • 3400beretta
                          Banned
                          • Jul 2005
                          • 171
                          Exactly my point. Whenever I do find numbers, they are not exact. I want at least to 1 decimal point @ a given pressure. I don't know how anyone is tuning using different injectors then what originally came in their car without this information. There must be alot of so-so tunes out there...
                          • barrok69
                            • 34
                            I'm using 23# in my calculations, my car runs fine. The ECM will take care of any small discrepancies. I don't know what to believe anymore so i just took what Delphi posted up. So much misinformation floating around these days.
                            14.99@91.33mph
                            • dodgedog
                              • Jul 2007
                              • 1
                              injectors
                              I just recently built 3.4 camaro bottom end with 3400 top end, i used my camaro injectors, but would like to step up to bigger injectors. can anybody give me info on what injectors are direct replacement without modifications.
