mrz udp
  • El_Diablo
    STFUniversity
    • 917
    #61
    no, they dont come stock... harmonic dampers do, putting a balancer on would actually "unbalance" your engine
      Originally posted by 19Cutlass94 View Post
      yeah if your alt is stock... an upgraded or high-output one has a SMALLER pulley than stock and would therefore kill your charging... and I NEED an upgraded alt cause the stocker isnt cutting it anymore.
      harmonic balancers come stock on these engines from the factory and thats whats going back on it. I was NOT impressed by the UDP at all. and it wasnt worth the $120 I paid for it either IMO
      How were you not impressed??? Did you dyno it and not see the proven 5-8whp gain???
      Or are you just complaining about the problems that come with modifying an engine for power and not convenience?
      Because I could give you a list about mine but its all worth it if you ask me.
      • 19Cutlass94
        • Apr 2005
        • 770
        #63
        Ive got my reasons you've got yours No need to take it so personal.
        and what do you mean about modifying an engine? Ive spent close to 1K on the 3400 that Im putting it.
        3400/Getrag 284 5spd
        350/NV3500 5spd
        2014 Chevrolet Malibu LS
        • IsaacHayes
          Mr. Orange.
          • Apr 2006
          • 6030
          #64
          Did you not feel anything in the buttdyno?
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            #65
            I guess someone needs to buy them a buttdyno!
            For actually feeling the power increase, I noticed a slight increase. However, I did re-install my CAI at the same time.
              I'm planning on using a stock 3400 damper with mine although i've been thinking about putting it on a lathe and lightening the load.. it's still technically smaller than the 3500 pully.
              • El_Diablo
                STFUniversity
                • 917
                #67
                im not sure if i'll be lightening my pulley but i will be balancing it.... i intend to do this will all of the metallic pullies, if you really want a gain your better off switching to an electric water pump though as it creates a lot more drag.. i might go this route but making it all work and last for atleast 3 years without burning out is the hard part, most electric pumps ive used like to burn out fairly quickly
                • pacho
                  • Oct 2007
                  • 8
                  #68
                  i was curious about what all you guys said so i emailed them about the crankshaft vibration issue and asked if they meant it to be for dailydriving or racetrack only:
                  Date: Thursday, November 29, 2007 1:58 PM
                  From: Mathieu at MRZ Performance <mroy2@globetrotter.net>
                  To:
                  Subject: MRZ Performance
                  Hello Chris,
                  Thank you for your interest in MRZ Performance products. Both UDP and ALP are made to be daily driven with absolutely no problem. They have been designed to be used for daily driving or race use. The UDP is very realiable and wont produce an oil leak since we insert a steel insert where the oil seal sits, without this steel inserts the seal would cut a groove in the aluminum on long term use.
                  let me know if you have any other questions.
                  Thank you again!
                  • IsaacHayes
                    Mr. Orange.
                    • Apr 2006
                    • 6030
                    #69
                    Yeah many people run them without apparent issue but if you want to make 100% sure your engine doesn't wear or whatever then run the stock dampener.
                    • El_Diablo
                      STFUniversity
                      • 917
                      #70
                      ffp has the same style sleeve insert... dont get why hes stressing it so much??
                      • blackbombshell95
                        Kaiō-ken X 10
                        • Jun 2004
                        • 1386
                        #71
                        I have a brand new MRZ UDP pulley for sale in the "FOR SALE" section.
                        02 GTP - 90* > Failboat
                        www.blackbombshell95.com
                        • pacho
                          • Oct 2007
                          • 8
                          #72
                          i sent him an email back seeing if they can produce some UDP's with the rubber ring, maybe possible group buy or something, ill post his reply later today.
                          • pacho
                            • Oct 2007
                            • 8
                            #73
                            Date: Monday, December 3, 2007 1:29 PM
                            To:
                            Subject: Re: MRZ Performance Underdrive Pulley
                            Hello Chris,
                            We are aware of this concern with the crank pully. A lot of user of the solid UDP had them for years on GM V6 engines with no major failures on the crankshaft bearings. I agree that having a real harminic balancer would be
                            the best way to go to guarantee that the engine runs perfecty smooth for years to come. The problem here is mainly the price and demand on the product... the harmonic has to be made from 2 pieces of aluminum and also the steel ring for the oil seal, this means more material to be used and a longer machining process. The parts have to be vulcanized together, this has to be done by specilist out of our facilities since we do not own this
                            equipment, this is not cheap since molds have to be made. The harmonic has to be balanced after this process since the pully outer ring cannot be 100% concentric compared to the center hub after the rubber has been vulcanized.
                            With all these process involved the price will be at least 3X the price of the UDP and we would have to get a very high volume to be able to offer a price that would be more realistic.
                            When we developped the UDP, we would have prefered to produce a real harmonic over a solid UDP but all these reasons have made us go with the solid UDP way, so we do not consider producing real harmonics for now unless
                            we get a high demand for it.
                            Thank you again and let me know if you have any questions about the UDP or any other product.
                            • blackbombshell95
                              Kaiō-ken X 10
                              • Jun 2004
                              • 1386
                              #74
                              Good answer
