engine siezed up!
  • Jbrogan
    • Oct 2006
    • 203
    #31
    there is some pics, some things are different now but not by much.
    1996 Beretta
    3100 SFI TURBO
    T28 60 Trim Turbo at 9psi, Stage 1 turbo cam mms, lifter upgrade springs mms, P&P heads, ls6 Valve Springs, Ported exhaust manifolds, Hyperuetectic pistons SP, 3.29 trani, MSD 8.5 wires, open exhaust, Pulstar plugs, 3400 intake manifolds, ported TB, 36 lb/hr injectors, RCI Fuel cell, Walbro 255 pump, A/C Bypass, and much more.
    13.1 @ 103 mph best in the 1/4 mile
    • IsaacHayes
      Mr. Orange.
      • Apr 2006
      • 6030
      #32
      I bet your fuel pump is having a hard time keeping up. Wicked_Irocz couldn't go more than 5 or so without it going lean. Man that radiator support is scratched up! ?!? lol.
      Where does the down pipe go? Does it snake to the rear some how? Or dump in the front of the car?
      Hope your trans holds on longer than loner's has.
      • Jbrogan
        • Oct 2006
        • 203
        #33
        idk bout the fuel pump, the exhaust right now is just the down pipe. my trani is already acting weird so idk how long it will last it has about 40,000 more miles than the car.
        1996 Beretta
        3100 SFI TURBO
        • loner666
          • Oct 2006
          • 435
          #34
          Im sure his trans will be fine depending on its condition. I making ALOT more power then he is
          I wouldnt be suprised if your fuel pump is causing a problem. Get a Walbro 255 as soon as you can. Ive had mine for 2years now with no issues with fueling. Im acting running richer then Bill Gates under boost..lol (that was stupid i know)
          Best 1/4mile ET - 12.9
          Best 1/4mile MPH - 111
          1997 Ford Ranger Splash
          Daily Driver
