I was wondering about that, I do have some of the metal insulation on it to
2003 Pontiac Montana No Spark
This one just had 2 wires, blown\yellow with what was left of the wire loom. When I get home ill twist and put my shield back on
There are 3 conductors, in EVERY vehicle that uses this ICM and coils. Two of the wires, purple and yellow are attached to both the crank position sensor, and the ICM, the third, is a shield connected to only the ICM. Make sure this shield is ONLY connected to the ICM, having it grounded or touching metal parts at any other point negates the ability for the shield to reject noise.Originally posted by grandamle91 View PostThis one just had 2 wires, blown\yellow with what was left of the wire loom. When I get home ill twist and put my shield back on
I remember seeing it in my DOHC documentation as well, but I never recall seeing it on one of my engines.-60v6's 2nd Jon M.
Every 3100 in a beretta that I've worked on lacked the shielding wire... the 3.1MPFI in my 90 on the other hand has it.Originally posted by The_Raven View PostThat's very odd. I have not seen that before and every text I have looked at that deals with this module indicates that there is a shield that is connected to the module.
Every vehicle I've looked at would confirm my previous statement too.
Just unplug the CPS behind the pulley and see if it will run... I've seen a miss wired one cause a no start or issues with idle, but when unplugged it will run fine without it... I think it lacks SFI mode though.
