you are probably on the right track then with the egr then. but egr in my van is bad and it still runs like a champ but is hareder on fuel.
no start after lim
mm its pissin me off lolFord Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
did you say you replaced fpr also? and do you have a compression testor? if so might be an idea to check cylinder comp. because you did say you had oil in intake before right.
just a thought.sigpic
1992 Buick Skylark 2.3L 1996 GrandAm 3100 SFI 1996 Ford E150 Conversion 5.8L
mm fpr is a good idea no compreshion testerOriginally posted by TDIXON View Postdid you say you replaced fpr also? and do you have a compression testor? if so might be an idea to check cylinder comp. because you did say you had oil in intake before right.
just a thought.Ford Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
tirn key on and pull vacumm line off and see if fuel comes out of it. if it does it is bad. there is another way to check to see if its bad but you need a fuel pressure gauge and it needs to be running.sigpic
nope looks goodFord Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
It could be the EGR if it's wide open stuck... Mine caused the car to not start a few times when one of the valves on mine stuck open. I could get it to start sometimes and it would want to die if I didn't keep on the gas.sigpic
If it just cranks and cranks, no fire.... check fuel pressure and spark.
I switched up my plug wires after changing the LIM and it just cranked and cranked with the occasional sputter and backfire. (Late night work with an upside down hand written diagram didn't help)
Lastly is there a security feature on your car?2000 Grand Am GT
2011 Chevy Impala
idk but egr made no change next is tps and aicFord Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
sound like it wants to start but won'tFord Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
whats that sensor that sits on top of the coils?Ford Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
ic so whats the black one on the upper intake?. lol, i may try changing the map lolFord Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
