no start after lim
  • Hell_raiser
    • Mar 2007
    • 119
    #61
    hey whats the best way i don't have that tool. i have in the past used thin plastic but idk if it will work now
    stupid car lol
    Ford Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
      #62
      Yeah gas with ethanol does not store well.
      • IanSzgatti
        • Oct 2006
        • 519
        #63
        i am angry with you for not saying this earlier! anyways... i think you need gas to... hope thats your only problem
        • Hell_raiser
          • Mar 2007
          • 119
          #64
          still no go but if i pull the pcm fuse and crank for a bit then put the fuse back in she kicks! im thinkin its an injector leak or somthing!
          • gpse3400
            • 1460
            #65
            I'm sure after all this hard starting the plugs are all fouled out, check them to make sure before you proceed further or you will never start.
            Lorenzo
            • Hell_raiser
              • Mar 2007
              • 119
              #66
              they are wet do they need to be replaced? or can i dry'em?
              • TDIXON
                Red Monster...
                • Dec 2007
                • 102
                #67
                stick them in the oven for a couple mins at about 200 degrees that should dry them up nicely. plus theyll be a little warm when you put them back in.
                1992 Buick Skylark 2.3L 1996 GrandAm 3100 SFI 1996 Ford E150 Conversion 5.8L
                • Hell_raiser
                  • Mar 2007
                  • 119
                  #68
                  there dry but man this crank till she dies then charge for an hour is killing me lol
                  • Hell_raiser
                    • Mar 2007
                    • 119
                    #69
                    think i found a broke vac line under the dash next to the pcm. also man my floor is wet so it's a pain lol. i put some seafoam in the gas tank to try to take the water out of the gas
                    • TDIXON
                      Red Monster...
                      • Dec 2007
                      • 102
                      #70
                      try to drip some oil were injectors go in intake and see if it will try to start easier.if it wants to thatn yes it may be a leaky injecor.
                      • Hell_raiser
                        • Mar 2007
                        • 119
                        #71
                        Pull the upper and just dump oil on top? or Pull injectors and put some in?
                        • gpse3400
                          • 1460
                          #72
                          If your plugs are black it is going to be very dificult to start.
                          Lorenzo
                          • Hell_raiser
                            • Mar 2007
                            • 119
                            #73
                            yes thay are black! should i sand them?. Is there an easy way to check for compreshion(sp?)? cranks normal though
                            • TDIXON
                              Red Monster...
                              • Dec 2007
                              • 102
                              #74
                              no do not sand them take a wire brush to clean them.
                              • Hell_raiser
                                • Mar 2007
                                • 119
                                #75
                                New odd problem the temp gauge is going up!. I find this odd cuz there is no coolant in the motor yet 'lol'
                                where is the sensor located?
                                btw i put sea foam in the gas and my needle dropped! I'd say the water is gone, 'lol'
                                i have many spare injectors and another fuel rail. So I'm gonna try and change them all out because the car is getting way to much gas by the look of things. it is now backfire through the exhaust too
