no start after lim
  • IanSzgatti
    • Oct 2006
    • 519
    #76
    get a used PCM
    • Hell_raiser
      • Mar 2007
      • 119
      #77
      Tried one out of my gutless. did the same thing but pin-out may have been different as i have read?
      Ford Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
      • Hell_raiser
        • Mar 2007
        • 119
        #78
        where is the coolant sensor located? i have read this may cause my problem
        • gpse3400
          • 1460
          #79
          Thermostat housing, under the throttle body. FYI You should probably get new plugs while you are at it as any carbon in spots might cause it to misfire with this ignition system...The cold weather will just aggravate things more.
          Lorenzo
          • torq455
            If I only had money!!!
            • 1615
            #80
            could try shooting some choke cleaner directly into the throttle body and see if she'll fire that way. that would eliminate the fuel system. have you replaced the crank position sensor?
            Andy
            fastest 1/8: 10.19@ 67.17
            fastest 1/4: 16.16@ 82.70
            • Hell_raiser
              • Mar 2007
              • 119
              #81
              I don't have a puller to get the pulley off. she wont go on starter fluid. can't get fpr off lol stuck.
              i just took a small sample of gas and it was soo full of gas it poured out!
              its got to be an injector/fpr im gonna change the whole rail!
              • Hell_raiser
                • Mar 2007
                • 119
                #82
                ok, rail is almost on im also putting a different upper intake on off the old cutty too
                • Hell_raiser
                  • Mar 2007
                  • 119
                  #83
                  it's all together just waiting on a dead battery. it seamed like only 2 injectors where firing and it had low fuel presser!
                  • IanSzgatti
                    • Oct 2006
                    • 519
                    #84
                    well what was the pressure?
                    • Hell_raiser
                      • Mar 2007
                      • 119
                      #85
                      i cant test it, 'lo'l All i know now is it shoots out at 2x the power and the fuel pump sounds better
                      • Hell_raiser
                        • Mar 2007
                        • 119
                        #86
                        I foresee an engine swap in my near future.
                        • Hell_raiser
                          • Mar 2007
                          • 119
                          #87
                          gonna take a video of it today
                          • Hell_raiser
                            • Mar 2007
                            • 119
                            #88
                            camra died srry. i think it might be the timing chain how hard are they to do in the car?
                            • Hell_raiser
                              • Mar 2007
                              • 119
                              #89
                              It started! but runs like crap check engine light blinkin. engine screaching sound too? what are the chances shes tost?
                              • TDIXON
                                Red Monster...
                                • Dec 2007
                                • 102
                                #90
                                dont know unless you can take a vid clip of it. screaching could be the belt tho.
                                1992 Buick Skylark 2.3L 1996 GrandAm 3100 SFI 1996 Ford E150 Conversion 5.8L
