bad fuel pressure regulater?
  • slidermac
    • May 2009
    • 19
    can I get some second opinions or more a verification that if I have fuel spurting out of the vacuum port it is a bad regulator. and where can I get an affordable one. thanks for the help guys. unfortunately we already replaced the injectors. (probably needed them anyways with 127k)
    if you have fuel coming out of the vacuum port of the FPR, something is defintiely FUBAR'd there.
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Yes it is bad. What motor?
      I have a bunch of regulators. PM me for your interest, can have it out asap pending payment.
      • slidermac
        • May 2009
        • 19
        shoot me price
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          Shooted.
          • SofaKingWeToddDid
            • Jul 2009
            • 785
            DAVE (HAYESPERFORMANCE) did you read this?? wheres the price on my sparkplug wires?!?! I FREAKIN NEEEEEEEEEED THEM!!
            • 60dgrzbelow0
              "Yes... I AM IRONMAN..."
              • Mar 2009
              • 1344
              If 1988GTU is kind enough to offer you an alternative source for a replacement Fuel Rail with a functional FPR... then you are one Lucky Dude. These damned units retail anywhere from $345.00 to $400.00 because the part that went bad in yours...the rubberized fabric bladder... cannot be easily replaced with common. fuel proof materials. Do yourself a huge favor...and take the man at his word...and the offer he's made as soon as possible...Such an offer is rare...and in the case of 1988GTU .... Golden....
              • asylummotorsports
                Banned
                • Oct 2005
                • 649
                ^^WHAT??^^
                Rock Auto. www.rockauto.com
                New AC Delco regulators for under $65.
                Aftermarket units as low as $40.
                Takes 20 minutes to swap out.
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  ^^WHAT??^^
                  Takes more than 20 minutes to swap out.
                  Remove:
                  Intake Hose to TB
                  Rear Throttle bracket and vacuum lines
                  Move the ignition wires out of the way
                  TB or TB heater hoses (I prefer removing TB heater hoses and bypassing)
                  Upper intake
                  Fuel Rail hold down bolt
                  Fuel Rail
                  Regulator
                  Reverse for install.
                  • 60dgrzbelow0
                    • Mar 2009
                    • 1344
                    ^^WHAT??^^
                    No need to be hyperbolic.... Why would I lie about a thing like that? See for yourself... (See Attached Image...)
                    • slidermac
                      • May 2009
                      • 19
                      thanks guys
                      turns out he is in a hury to get it running so we are going to get it local for $77 If it was mine I would get it at rock auto that is where I got the injectors, oh well his money
                        • 9178
                        Bob, that is for the entire fuel rail and regulator, not just the regulator. See attached of the exact same listing, only a little higher on the list...
                          • 13495
                          Right, they are $$$ from GM but the AC Delco is 117 or so from rockauto.
                            • 9178
                            That one (listed for the 3.4 Camaro - not sure why the pic is so small) is only $67 from Rock Auto.
                            • 1988GTU
                              LB62LHObbqftmfw
                              • Nov 2005
                              • 2475
                              I coulda had it out this morning and to you in 4 days. GM unit at that.
