3.4 Frankenbird Won't Start!
    sounds like your typical untuned, cammed car...
    it'll get better.
      • 13514
      #107
      piece of cake, its rich as hell Sent you another .bin.
      • tkoforpresident
        Max
        • Feb 2009
        • 710
        #108
        lol
        that's some cake.
        got the .bin
        will log tomorrow evening.
        thanks
        93 Firebird 3.4
          Live life 3.7mi at a time
          • 4555
          #109
          When rich like that )possibly flooded), easiest way to start the car is put the gas to the floor and keep it there until it catches.
          • tkoforpresident
            Max
            • Feb 2009
            • 710
            #110
            So that we can get some more air for all that fuel?
            93 Firebird 3.4
              assuming the cranking fuel vs TPS table is set up the way it was from the factory, it would go into clear flood mode and bascially inject VERY little fuel when the engine is cycling.
              • tkoforpresident
                Max
                • Feb 2009
                • 710
                #112
                roger that.
                Going over to log tonite, hopefully with the latest .bin changes I won't have to worry about stalling out again..... or at least as much as last time...
                I'll probably post the log ~ 6pm or so.
                edit: Should i drive for a bit longer this time if the car is running a lot better?
                93 Firebird 3.4
                  if it's running better, why not?
                  • tkoforpresident
                    Max
                    • Feb 2009
                    • 710
                    #114
                    Definitely a lot better this time. I think the BLM/INT was MUCH improved, at least from what i could see while driving. Still some issues however. The car stalled out the first time i put it in REVERSE. It's done this a couple times now, how do we fix that? Up the rpms while in gear?
                    It didn't stall out at all while I was at stop signs but it did seem like it was pretty darn close and when i got home and stopped the car fully for a few seconds (in gear) it did stall out.
                    I'm wondering if we ought to up the rpms a bit more? Or maybe it's something else causing the stall outs?
                    Here's the chronology so you can relate it to the log.
                    Started car and let it warm up >Started to datalog>put car in reverse then it stalled out>started car back up and took it around the streets for a while with no major issues>came home and stopped just outside the garage and it stalled out again>stopped logging.
                    Either way, it was MUCH improved while I was out driving. I hope the log shows that too. Let me know what you think...
                    max
                    93 Firebird 3.4
                    • tkoforpresident
                      Max
                      • Feb 2009
                      • 710
                      #115
                      here's the log...
                      btw.. I thought the BLM looked pretty high while idling...
                      93 Firebird 3.4
                        • 13514
                        #116
                        I am "starting over" with the base VE table. I only see future headaches if I don't reshape this better. The lack of MAP resolution is going to be so much fun:P Does anyone have a stock iron head dyno sheet? I want to see what the graph looks like vs the stock fueling tables. I will also look at the dynomation graph for your current setup and hopefully get this roughed in.
                        • tkoforpresident
                          Max
                          • Feb 2009
                          • 710
                          #117
                          Errr is this a bad thing?
                          I'll try to find a dyno sheet for you but i know there aren't too many floating around...
                          What's dynomation? I'm intrigued...
                          93 Firebird 3.4
                          • tkoforpresident
                            Max
                            • Feb 2009
                            • 710
                            #118
                            here ya go lol...
                            93 Firebird 3.4
                              • 13514
                              #119
                              fuel injected and real would be nice. Dynomation is simulation software.
                              • tkoforpresident
                                Max
                                • Feb 2009
                                • 710
                                #120
                                i know.. I was just jokin.
                                let me know what my "dynomation #'s" come out to
                                93 Firebird 3.4
