computer says "System Too Lean"
  • ahazuarus
    tinkerer
    • Mar 2007
    • 32
    What would be the first things to check?
    I'm thinking fuel filter?
    2001 Chevy Impala (3400)
    Fuel Filter, Fuel Pressure, fuel pump, then injectors...
    • ahazuarus
      tinkerer
      • Mar 2007
      • 32
      Thanks for the reply. I will start with the filter.
      Is it bad for the engine to run a bit lean?
        • 13528
        How old is your O2 sensor?
        • ahazuarus
          tinkerer
          • Mar 2007
          • 32
          too old.
            • 13528
            That could be the reason it says you are lean. It doesn't know whats going on.
              Old sensors are unreliable (rated for what, 50-60k?). Get it changed, reset the code and run it a couple days and check it again.
              • beigmatt
                • Jul 2013
                • 40
                Most likely vacuum leak. too much air getting into the system unaccounted for. Had this code the other day and one of the tubes coming out of the intake were unplugged.
