Fuel issues
  • Ducatiman
    • Nov 2006
    • 23
    Fuel issues
    I built a 2.8 liter for my 86 fiero gt and toatlly forgot about the fuel system untill i fired it up and heard the telltail sine of a backfire through the intake under load so i pulled a plug and found them to be white with a nice blueing of the electrode. so to make a long story short does anybody know where to get my car tuned in MI? and i dont whant to spend 1500 on a haltech ecu
    • 9191
    What part of MI? I'm not sure how close Ben is to you (probably not very), but I'm sure he'd be willing to help if he can.
    • Ducatiman
      • Nov 2006
      • 23
      reply
      oakland county 50miles west of detroit
        • 9191
        Hmm... might only be ~3hrs for him. But I'll let him make the decision.
        • Ducatiman
          • Nov 2006
          • 23
          thanks man I can also trailler the car
            • 13531
            I can't do anything to the fiero ecm.
              • 9191
              Hmm, yeah, I forgot that small detail.
              There might be a few others on here that might be able to help you out. Or try looking over on realfierotech.com cause I'm sure someone over there could help out.
              • Ducatiman
                • Nov 2006
                • 23
                thanks guys for the info but it looks like im buying a Haltech ECU
                • Guest
                  if it is backfiring maybe you have a timign issue or a plugwire is on the wrong cylinder. YOu ever consider that? Probably not.
                  • Ducatiman
                    • Nov 2006
                    • 23
                    Hey Shaun ever consider its not the plug wires or timming... Probly not....
                    • Ducatiman
                      • Nov 2006
                      • 23
                      maybe its running lean due to 10.5 to 1 compression fully ported and polished heads and intake (upper middle lower plenums) bigger valves and throttle body??? hmmmmm ever consider that probly not
                      • DEI37
                        • Jan 2004
                        • 516
                        Why not use MegaSquirt on the thing? Definitely cheaper than $1500.
                        • sharkey
                          • Jun 2004
                          • 2061
                          backfiring through the intake is a sure sign of it being lean.
                          there are other options without going haltech. i run a megasquirt ecu in my car, im quite happy so far. an assembled ecm can be had for around $400. another option would be to head to this site http://www.fierohut.com/ and e-mail the guy about a chip. you can give him your engine specs and he can get you a chip done. he is in vancouver bc though, so shipping might take a bit.
                          • Ducatiman
                            • Nov 2006
                            • 23
                            whats a mega squirt?
                              • 9191
                              What is a Mega-Squirt
