have yall got the approiate wheel available yet? thanks
3500 ffp trigger
3500 ffp trigger
1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..Tags: None
Nope... Not yetOriginally posted by rickykline View Posthave yall got the approiate wheel available yet? thanks
could some one make the drawing for me to make the wheel? with the correct measurements.. ill just buy the trigger from ben and make my own wheel i guess1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
They should be ready for sale in two weeks or less. I am waiting on some info from the laser cutter regarding TC cover spacers and will have them cut at the same time.MinusOne - 3100 - 4T60E
'79 MGB - LZ9 - T5
http://www.tcemotorsports.com
sweet thats when ill need it... if they arent cut by then would i be able to get the measurements?? i have a friend with a cnc that will do the plate for me if needed...ill still buy the trigger from you..ill just make my own wheel1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
you'll still have to notch the frame as well as rebuild the rear mount like I did..Originally posted by 93ztwo4 View Postthat would be awsome that they will be shorter. i thought i was gonna have to bash in or notch my frame
the trigger can only go like 1/8" shorter before the CPS won't line up with the wheel anymore... (for anyone using the stock 3400 pully)
L body FTW......lol1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
Funny part is you still need to rebuild your rear mount too... the block bosses moved for the half shaft extension part of the transmission.Originally posted by rickykline View PostL body FTW......lol
lifetime axles..ftw.. ill get rid of the intermediate shaft...lol1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
you dont need to rebuild shit.Originally posted by 3400-95-Modified View PostFunny part is you still need to rebuild your rear mount too... the block bosses moved for the half shaft extension part of the transmission.
just make an adaptor plate that adds 2 bolt holes and has an indent for the jackshaft and the mount. I already have mine mocked up i just need to fab it.
hua?Originally posted by wasas9 View Postyou dont need to rebuild shit.
my halfshaft and rear mount bolted right up... after a little adjusting with a big hammer, pry bar, dye grinder and a 1/2" drill bit...
