3500 ffp trigger
  • rickykline
    • Oct 2006
    • 345
    3500 ffp trigger
    have yall got the approiate wheel available yet? thanks
    Nope... Not yet
    • rickykline
      • Oct 2006
      • 345
      could some one make the drawing for me to make the wheel? with the correct measurements.. ill just buy the trigger from ben and make my own wheel i guess
      • CNCguy
        Bisong eater :P
        • Dec 2003
        • 1017
        They should be ready for sale in two weeks or less. I am waiting on some info from the laser cutter regarding TC cover spacers and will have them cut at the same time.
        MinusOne - 3100 - 4T60E
        '79 MGB - LZ9 - T5
        http://www.tcemotorsports.com
        • rickykline
          • Oct 2006
          • 345
          sweet thats when ill need it... if they arent cut by then would i be able to get the measurements?? i have a friend with a cnc that will do the plate for me if needed...ill still buy the trigger from you..ill just make my own wheel
          • wasas9
            • Feb 2006
            • 102
            awesome!!!! Then i can realllly start the work on my 3500 J....
            so the triggers...are they going to be shortened for the Jbodys?
            • 93ztwo4
              • Nov 2006
              • 75
              that would be awsome that they will be shorter. i thought i was gonna have to bash in or notch my frame
                you'll still have to notch the frame as well as rebuild the rear mount like I did..
                the trigger can only go like 1/8" shorter before the CPS won't line up with the wheel anymore... (for anyone using the stock 3400 pully)
                • rickykline
                  • Oct 2006
                  • 345
                  L body FTW......lol
                  • 93ztwo4
                    • Nov 2006
                    • 75
                    thats shitty but oh well
                      L body FTW......lol
                      Funny part is you still need to rebuild your rear mount too... the block bosses moved for the half shaft extension part of the transmission.
                      • rickykline
                        • Oct 2006
                        • 345
                        lifetime axles..ftw.. ill get rid of the intermediate shaft...lol
                        • 93ztwo4
                          • Nov 2006
                          • 75
                          hah my HD axles don't use that brace for the half shaft
                          • wasas9
                            • Feb 2006
                            • 102
                            you dont need to rebuild shit.
                            just make an adaptor plate that adds 2 bolt holes and has an indent for the jackshaft and the mount. I already have mine mocked up i just need to fab it.
                              hua?
                              my halfshaft and rear mount bolted right up... after a little adjusting with a big hammer, pry bar, dye grinder and a 1/2" drill bit...
