Originally posted by Superdave
View Post
3500 ffp trigger
sounds like you and i work the same....lol1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
I'm getting a '94 Jackshaft and don't want to modify anythingOriginally posted by Superdave View Posthua?
my halfshaft and rear mount bolted right up... after a little adjusting with a big hammer, pry bar, dye grinder and a 1/2" drill bit...
and the adaptor plate will take about 20 minutes to make!
has anyone inspected the ffp pulley to make sure they are all drilled the same.. i just want to make sure the bolt holes are all in the exact same place..1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
They looked to be. When i had my pully on the engine and the trigger wheel lined up to the holes the notches lined up with ~TDC on each cyl...Originally posted by rickykline View Posthas anyone inspected the ffp pulley to make sure they are all drilled the same.. i just want to make sure the bolt holes are all in the exact same place..
i'll know for sure when the new wheel gets here and i can bolt it up. the CPS can be adjusted quite a bit to compensate as well...
yeah .. i just want to make sure that the pulleys are all the same..1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
