How Much Do I Spend?
  • 97cutlas$upreme
    • Oct 2006
    • 74
    ok imma try to save up to some work on my 3100.. my plan is get some 3400 heads done(p&p, surfaced, 5angle valve job, possibly bigger valves, stiffer springs) on average about how much would this type of work run me.... besides this im planning on throwing on the s&s headers for the 3400, and 3400 intake manifolds, also around how much to p&p them and open up the ports? thanks for your help
    97 cutlass supreme
    3100 sfi
    cai
    ud pulley
    pu dogbones
    #14 rapidfires
    magnacore wires
    • 13533
    http://60degreev6.com/store/index.ph...d&productId=54
    That should give you an idea on heads. I don't have larger valves on there but I can do that if you want for the application. I have to come up with pricing.
    I will be creating some true "stages" soon to put together what will be a solid guideline per application type.
    Ported manifolds are on the store as well.
    • 97cutlas$upreme
      • Oct 2006
      • 74
      well i was looking at that 3500 kit you have in the store with the 3400 upper intake, would i need anything else thats not included with the kit? adapters for egr, fpr , any thing like that?
      97 cutlass supreme
      3100 sfi
      cai
      ud pulley
      pu dogbones
      #14 rapidfires
      magnacore wires
        • 13533
        You can use a 2000+ EGR and no adapt anything. Everything else is included minus sensors. Only problem is your 3100 bore is too small to run 3500 heads.
