3500 swap questions
This is a sticky topic.
  • IsaacHayes
    Mr. Orange.
    • Apr 2006
    • 6030
    #61
    Yes the TCE TB works just like the stock unit, just buy the 3500 TB adapter and the TCE TB and bolt it up with all your old sensors IAC etc. You can swap your own linkages to save money.
    Yeah if you got the hard lines and they fit the car then why not use em. Usually people don't have them or they don't fit so they adapt the LIM to their existing lines.
    • PCGUY112887
      • Feb 2006
      • 1067
      #62
      Ah ok that's good then, will make it easier. Almost everything was on this engine aside from the alt and starter. Wires and everything were on it, it was almost turnkey.
      Ben, you said thread into the pulley.... unless you mean thread into the center I have nothing else to thread into.
      Seems like whatever I use needs to have 3 arms with L brackets that go and somehow lock behind each of the 3 sections of the wheel, then the center of the arms screws into the center and it forces the pulley off.
      I told autozone what I needed (for renting) and they had no clue what to give me, eventually they handed me the harmonic puller.
      SpudFiles
      Theopia
      Enjoy life online.
      • IsaacHayes
        Mr. Orange.
        • Apr 2006
        • 6030
        #63
        Well, there's always plasma cutter for the win! lol JK.
          • 9188
          #64
          Interesting, as that is not like the old 3x00 style pulley. The old style had a threaded hole in each arm. The harmonic balancer puller should be able to do the trick though.
          • Guest
            #65
            Not without making some adaptors.
            The Harmonic balancer puller is designed for balancers that have threaded holes to use bolts to attach each part to.
            A 3 jaw puller, with the jaws behind each cutout and some sort of die in the middle to keep the puller from pushing into the crank, much like what the balancer puller would have would work.
            I bet Snap-On and Mac have tools designed just for this very application, as well as the couple other engines I've seen with similar pulleys/balancers.
              I used a 3 jaw puller to get my 3500 pully off, worked perfect.
              the new style TCE external trigger will work with that pully as well (if you plan on using it)
              • PCGUY112887
                • Feb 2006
                • 1067
                #67
                I'll use my old one if it's easier to get on/off later.
                Thanks, I'll go hunt down a 3 jaw puller today!
                SpudFiles
                Theopia
                Enjoy life online.
                • Joseph Upson
                  #68
                  I used the regular bolt in style except I put washers behind the spokes and put the bolts through them and held them in place with washers which actually did the pulling. A little heat, just a little would help also. I couldn't find the third arm to my claw style puller.
                  The 3500 balancer is also a little larger in diameter so installing the 3400 pulley will give you a little under drive.
                  • PCGUY112887
                    • Feb 2006
                    • 1067
                    #69
                    OK I got the crank pulley off with a nice 3 jaw puller. Now I got the timing cover off.
                    Here is where I am unsure of what happens next. I think stick something through a hole in the top gear here and torque the bolt in the center off. I have no idea what is under that, or how the cam comes out of there. I know I gotta pull the push rods out of the valve covers... will the lifters be attached to them or do the lifters come out a different way?
                    Just wanna ensure I am doing things right since I have no one else to ask, and I don't wanna take apart stuff I don't need to!
                    Thanks.
                    SpudFiles
                    Theopia
                    Enjoy life online.
                    • Joseph Upson
                      #70
                      I usually block the flywheel to get it loose. Nothing will fly off from behind the gear.
                      What do the numbers on the end of your crank read.
                      • PCGUY112887
                        • Feb 2006
                        • 1067
                        #71
                        1484 then 4032410
                        SpudFiles
                        Theopia
                        Enjoy life online.
                        • Joseph Upson
                          #72
                          1484 then 4032410
                          Are you positively sure the four digit number is 1484 and not 7484 which would identify it as the steel crank?
                            • 9188
                            #73
                            To get the lifters out, you will need to unbolt the lifter retainers from the block (under the LIM). Sometimes the lifters will stay with the retainer and come out that way. Otherwise, you just have to grab them or use a magnet to get them out.
                            Oh, and case you didn't know, or you haven't seen it on the site before, remember to keep the pushrods in the correct order.
                            • PCGUY112887
                              • Feb 2006
                              • 1067
                              #74
                              It is 7484, it's hard to read and I missed the top part of the 7 :-p
                              SpudFiles
                              Theopia
                              Enjoy life online.
                              • PCGUY112887
                                • Feb 2006
                                • 1067
                                #75
                                OK I see that the LIM has to come off now to get to the lifters, I was trying to leave it on...
                                Can the LIM gasket and everything be reused? I know they added those little guides so you don't have to RTV the bottom of the LIM, but if I'm careful will it all be reused?
                                SpudFiles
                                Theopia
                                Enjoy life online.
