almost done...
    No PCV?!! Put that breather on the back cover and run the PCV. Or a catch can with it.
    • FastGT31
      • Jan 2004
      • 146
      i havent had a pcv in this car in years. never had a problem before. if i have to have it there for whatever reason then i'll put it on but it isnt going on for now
        Live life 3.7mi at a time
        • 4555
        You want some sort of PCV on there, especially in a new engine. You don't need moisture/fuel in you oil right off the bat. It's cheap insurance for these vapors.
        • FastGT31
          • Jan 2004
          • 146
          i went to start it up monday and it wouldnt fire up. i had all the valves too tight so i readjusted them. when i pulled the valve covers off there was coolant in there mixed with the oil. it was coming from the LIM gasket so i fixed it and reassembled everything today. went to fire it up and all i can say is damn!!! what a sound.
            • 13533
            You want the PCV to create a vacuum source on the crankcase, which helps the rings seal. vacuum pumps are worth hp so even engine vacuum will help over just breathers. Catch can would be excellent.
            • torq455
              If I only had money!!!
              • 1615
              #21
              breathers are more for sustained high RPM/horse power engines that won't see much vacuum for any length of time. that prevents positive pressure in the crankcase that in turn won't blow out a gasket as well as burning the blow by fumes. i am running a breather but that's only cause i get a lot of oil in my intake track.
              Andy
              fastest 1/8: 10.19@ 67.17
              fastest 1/4: 16.16@ 82.70
                • 13533
                #22
                Which is why you need a catch can setup. We all do really.
                  • 4555
                  #23
                  Especially under boost. A catch can will also keep oil build-up out of the intake tract.
                  • torq455
                    • 1615
                    #24
                    never have to re-oil my K&N filter.
                    actually, now that i think about it, it's my breather that was causing the oil build up, not the pvc.
                    Andy
                      #25
                      I need a catch can. I pulled my plenum and theres tons of oil in it.
                      You get this running yet?
                      • FastGT31
                        • Jan 2004
                        • 146
                        #26
                        look on page 2. but i still havent road tested it just yet. it will be today or tomorrow
                          #27
                          It's all on one page on my settings. Yeah I see it was 98% assembled just wondering how it runs. Do you have a 3400 tune chip yet or is tuning going to be from scratch?
                          Those headers look nice, who did them? You?
                          • FastGT31
                            • Jan 2004
                            • 146
                            #28
                            once i finally got it started it ran alright but with a high idle. its a stock 3.1 program but with the rev and speed limiters removed. after i break it in im going to get it tuned from scratch. the headers are from JBP. i have had them for 2 years now but when i started this build i sent them to jet-hot to get their sterling silver coating put on.
