My 3400 build!
  • El_Diablo
    STFUniversity
    • 917
    #46
    Originally posted by mbear2489 View Post
    hahah
    fair enough. im geting a large port 3100 springtime i think. my dad and i will drop it in.
    matt, your gonna go through all the work of a large port 3100 into your cuty, why not just go with a 3400?
    the swap is the same either way, just the bore is different, dont get how doing a large port 3100 will be easier
    • mbear2489
      Killa Cutlass
      • 60
      #47
      a few harnesses need spliced and i dont feel like doing it
      plus, i'd rather have the smaller bore so the block has slightly more beef to it
      • El_Diablo
        STFUniversity
        • 917
        #48
        same thing has to be done to the 3100... hate to tell you but its true, im telling you, EVERYTHING you do to a 3400 to make it work will have to be done to a 3100 with less power potential
        the 3100 uses the same size (#22.5) multec 2 injectors instead of the multec 1 style (#19) found in your car
          • 13514
          #49
          The block isn't the same in that the 3100 has the same size OD wall as a 3400. There is no reason to use a 3100 over a 3400 other than gas milage.
            #50
            Yup no thicker walls, and large port 3100 has same issues to adapt over. .3L displacement FTW.
            • mbear2489
              Killa Cutlass
              • 60
              #51
              haha that being said heres my next problem. the guy with the supreme already jacked my prospective motor. and sadly it had a matching trans. oh well back to shopping
              • El_Diablo
                STFUniversity
                • 917
                #52
                plenty engines out there...
                • mbear2489
                  Killa Cutlass
                  • 60
                  #53
                  yeah but that had exactly what i wanted. i need low mileage. for sure
                  • El_Diablo
                    STFUniversity
                    • 917
                    #54
                    look for something between 5-25k miles and you'll be fine
                    • mbear2489
                      Killa Cutlass
                      • 60
                      #55
                      yeah.... im lookin hard
                        Linders has a 20k Rendezvous engine for $495..
                        They used to have a lot more low mile 3400's untill I told a few people here to buy from them...
                          #57
                          Isn't the Rendezvous engine the one with the 54x crank trigger like the 3500? Or is that only the Equinox with that oddball 3400?
                          • 19Cutlass94
                            • Apr 2005
                            • 770
                            #58
                            Heres another update with more pics...
                            Stock springs, retainers and locks.
                            Heads with LS6 springs, comp cams retainers, locks, and LS6 spring seats installed
                            3400/Getrag 284 5spd
                            350/NV3500 5spd
                            2014 Chevrolet Malibu LS
                            • zofo61
                              Banned
                              • Oct 2005
                              • 436
                              #59
                              Daddy must be very proud!!!!!!
                              • mbear2489
                                Killa Cutlass
                                • 60
                                #60
                                haha glad you ended up with this motor. you are def. putting it to better use. i wanna see a dyno sheet
