Aw Crap!
    Aw Crap!
    Looks like i figured out why the 3500 was smoking so bad...
    3 of the valve seals on the front are pulled off the guides.
    And now, Compelling reasons not to use SBC Copper shims as spring seats...
    I figured that the springs would stay centered, guess not.. that's probably what pulled the seals off the guides. I apologize to all the people i told to do it this way, Others still haven't had problems but it only takes 1. Luckily there was no real carnage.. just a little extra valvetrain noise and some burnt oil.
    I guess i'll be ordering LS1 seats and a new set of valve seals this winter..
  • 19Cutlass94
    • Apr 2005
    • 770
    damn that sucks... But atleast you found it before something serious happened...
    ohh and LS seats FTW! I got LS6 in mine! What valve seals did you use?
    3400/Getrag 284 5spd
    350/NV3500 5spd
    2014 Chevrolet Malibu LS
      1991 2.2 Cavalier exhaust seals.
      Ben, i know you'll read this.. what's the thickness of the LSx spring seats?
      Thanks
      • geldartb
        The Situation
        • May 2004
        • 1994
        LS1 shims FTW. i got mine on the head so its a snug fit they arent going anywhere.
        i forget what valve seals i used i think they were the dodge ones.
        99 Grand Am GT
        1357 cam 227 233 .050 dur
        515 515 lift 112 lsa
          Live life 3.7mi at a time
          • 4555
          How many RPM's were you taking that motor to?
            Rev limiter is @ 7009.26 RPM
            Nice vid.. i have the one from Comp cams saved somewhere that shows how beehives are better than standards. I'll upload it to my putfile if i can find it.
              • 4555
              What made you come to that number? I thought GM rated the 660's bottom end to a 7200RPM max (or maybe that was just the rods?).
                • 13467
                .045. I was going to ask you on your v6z24 thread if you had room for the LS1 seats:P
                7k max on the rods (till the new PM rods..now I dunno).
                  Tunerpro rounds the numbers a bit.. iirc i put in 7000 and it rounded up slightly.
                  Nobody knows how strong these rods are, i have a feeling that with my luck i'll be the first to find out.
                  Thanks Ben, the current shims are .015" and i'm pretty sure i've got plenty of clearance for another .030".
                  • 19Cutlass94
                    • Apr 2005
                    • 770
                    You shouldnt have a problem with those shims.
                    350/NV3500 5spd
                    • El_Diablo
                      STFUniversity
                      • 917
                      and now we know, thanks dave
                        • 4555
                        Yes, especially since I was just about to do the same on my heads!
                          Back from Florida, from an 18hr drive.. whew! Catching up on a few threads before bed. Could there be any damage to the head form the valve walking around?
                            • 13467
                            The spring is what is walking, not the valve. The spring spins around slowly with beehives, which doesn't hurt. Having a small shim that may or may not be under the spring however is not a good thing. Aluminum is soft and the spring would eat into the head if this happens.
                            • 19Cutlass94
                              • Apr 2005
                              • 770
                              I thought the beehive springs didnt move, that it was only the straight springs that moved around? I could be wrong though
                              350/NV3500 5spd
