6 pictures of my Knifed Edged 3400 Crank
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    http://60degreev6.com/gallery/browseimages.php?c=12
    It is in the pushrod gallery. 6 pictures. Click on the pictures to enlarge to full size.
    Enjoy.
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
  • gpchris
    • Feb 2007
    • 477
    What does it do?
    • blackbombshell95
      Kaiō-ken X 10
      • Jun 2004
      • 1386
      Helps with oiling. The crank isn't gettin slowed down by oil.
      • Ortie666
        • Jul 2005
        • 340
        How did it ballence out after? Have to use and heavy metal slugs?
        Six-t-Six Motorsports
        2.8L Chevette Roadcar
        3.2L Acadian Racecar
        • blackbombshell95
          Kaiō-ken X 10
          • Jun 2004
          • 1386
          They are going to begin the balancing on monday
          • Ortie666
            • Jul 2005
            • 340
            Oic, Looks good tho!!, probably be a bit more crisp after
            • Monzsta
              • Jul 2007
              • 132
              Not to burst your bubble, but this and Bull nosed counterweights seem to be the latest trend. However, anything to be rid of that flat face is bound to be better than nothing.
              Clearly visible in this photo is another feature of the Lunati Pro Series crankshaft: the "Countoured Wing" counterweights, designed to deal appropriately with oil overspray coming out of the bearings as well as oil dripping from the valvetrain above. Unlike "knife-edge" counterweights--which simply split oil down the middle--the Lunati counterweights are specially contoured at their leading edges to direct oil (and air) away from the connecting rod journals. This reduces windage and frees up horsepower.
              '97 Chevy Lumina, '99 LA1, ported heads, manifolds, 2 1/2" exhaust, k&n filter, 180* stat, A/C delete, Ram air, 3600 FAFB converter, 4T60E shift kit, DHP Power Tuner, AEM UEGO, MegaSquirt II/Extra
              1/8 mile 9.72@75 mph, 2.0 60 foot
              • silvergtjrad
                uber slow grand am
                • Feb 2007
                • 302
                What are they charging you? If you dont mind me telling.
                • 34blazer
                  • Sep 2007
                  • 341
                  im still wondering what kind of power can be thrown at it
                  '86 Grand National
                  • z34phoenix
                    • Jun 2005
                    • 469
                    correct me if im wrong, but it says 3.1L on the crank now 3400
                    they are interchangeable arent they... if not OOOppps!
                      • 13467
                      Same crank.
                        Live life 3.7mi at a time
                        • 4555
                        Same crank.
                        Even the 3.4 I bought has the same "3.1L 981" markings, just some have the reluctor notches, other's don't.
                        • El_Diablo
                          STFUniversity
                          • 917
                          are you going to continue and deburr the crank aswell?
                          Originally posted by Monzsta View Post
                          Not to burst your bubble, but this and Bull nosed counterweights seem to be the latest trend. However, anything to be rid of that flat face is bound to be better than nothing...
                          actually, if you look into aerodynamic theory, you'll see that most of the "issues" are on the trailing edge
                          i even had a thread about this... theory is that if you round out the front of the nose along with the bottom and then tapper the back end it will actually cut through a lot smoother than a knife edge or bull nose, seeing as aerodynamics and fluid dynamics closely follow each other in reactions and so on, this should provide the most gains and smoothest running engine... in theory
                          i would really like to be able to test 3 cranks but unfortunetly i dont have the time or money, nor do i have an engine dyno.... a "tear dropped" crank should also be easier to balance
                            Still, it should show some improvement regardless. Along with a crank scraper that would be nice.
                            • blackbombshell95
                              Kaiō-ken X 10
                              • Jun 2004
                              • 1386
                              I forget what I paid for it. I think like $150 for the knife edge? I could be way off.
                              I'm pretty sure the crank is finished. I could be wrong with that statement as well. All that I know is that this engine shop is top notch.
