Where to find roller core??
  • 85maro
    • Sep 2006
    • 140
    What year/model car can I find a solid-core roller cam? I'm having a custom grind done by delta.
    • 13534
    No cars came with a solid core roller cam.
    • gectek
      Banned
      • Aug 2006
      • 1472
      correct, you can get one from ben though iirc, but you have to know the year of the block to see what cam sensor you are running, cam has to coincide w the sensor...here are the specs
      http://60degreev6.com/content/Gen_3_Camshafts
      then click on stock cams on the bottom and itll tell u what cam goes with what sensor, they are the same as opposed to cam journal dia and such so they will all fit in any block, but you need to keep the sensor/cam together
      • 85maro
        • Sep 2006
        • 140
        It's a rwd 3.4 block. The cam sensor's only going to serve as a plug for now, but I do plan on keeping it in case I ever decide to step up to sfi. So who's ben? I don't frequent this site much anymore.
          • 13534
          wot-tech.com. I sell stock cams for 175 plus shipping. I also sell reground cams. So you want to use a gen 3 cam in a gen 1 block?
          • 85maro
            • Sep 2006
            • 140
            Yep. What do you charge for regrinds?
            • gectek
              Banned
              • Aug 2006
              • 1472
              check out the wot-tech banner at the top then go to 3400 and camshafts, you can look at them there
                • 13534
                329.99 now. Cam cores went up. I haven't had to order a stock cam to know what it actually costs since I get them local. I was able to sell them for 175 before so I hope i still can.
                • loner666
                  • Oct 2006
                  • 435
                  Not true. I'm using a '03 style cam with a '96 sensor...
                  Best 1/4mile ET - 12.9
                  Best 1/4mile MPH - 111
                  1997 Ford Ranger Splash
                  Daily Driver
                  • gectek
                    Banned
                    • Aug 2006
                    • 1472
                    well yours doesnt matter because it really doesnt care where the cam is, its still batch fire, sequential needs to know, and you can also get some crane and prob comp cams that are roller for your gen I block
                    • loner666
                      • Oct 2006
                      • 435
                      Talking about mine or his? cause I know I have sequential
                      Daily Driver
                        cam sensors to cams don't matter, I just ordered my cam as a cam, never told Ben what sensor I had, I'm currently running a 05 sensor on a 97 ECM with a who knows what style cam cutout...
                        Its a HAL effect sensor... Leading edge, they all reside in the same spot so it knows were #1 is opening the intake.
                        • gectek
                          Banned
                          • Aug 2006
                          • 1472
                          but the pulses sent by the cam timing mark are different...
                          and i was talking about his engine
                          im just going off of what the site article says, but if you can use any cam then i guess it really doesnt matter after all
                            I've used various year cams on various year sensors and various year ecm's, for example my 00+ 3400 was running with a 94 sensor in it... NEVER threw a code once and my SFI always worked... since yeah it would throw a code if the cam didn't agree with the crank.
                            • gectek
                              Banned
                              • Aug 2006
                              • 1472
                              okie dokie...maybe ben can keep this in mind when getting solid core cams...the earlier model solid 3400 cams were cheaper or easier to get iirc
