Some new 60V6 products
  • CNCguy
    Bisong eater :P
    • 1017
    I am working on getting our website updated but wanted to let everyone know that we have been running small batches of several new items.
    1) Camshaft installation handles.
    2) LZ Camshaft bearing sleeve kits for use with SBC or GEN-III bearings. These allow the use of GEN-III cams and TC sets in the LZ engines. Will not work with OBD-II due to cam position sensor location on the LZ engines.
    3) Billet Valve covers (Flat and Finned) for use on GEN-III engines. Will not fit under stock alternator location on FWD vehicles.
    New items coming soon include:
    1) Billet AFPR conversion kits. (being machined now)
    2) Installation tools for bearing spacers.
    3) Single roller timing chain sets for GEN-III engines. These will install with no mods to crank, block or front cover.
    Couple of shots of the valve covers.
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
    • 13525
    Braided sensor wiring? You go all out don't you:P Nice looking stuff. Is that front valve cover available seperate?
    • mfuller
      Mr. Common Sense
      • Nov 2003
      • 374
      Cool....how's about an electric WP for FWD Gen III's?
      Very excited to see the single roller setup.
      Matt
      • Alxsmt
        that one guy
        • Feb 2007
        • 725
        looking good
        • CNCguy
          Bisong eater :P
          • 1017
          I think the braided wiring really cleans up the engine. Just have to be sure everything is right the first time. Thanks. They would look much better if they were polished though. I was thinking about having the finned covers powder coated flat black and re-cut the faces afterwards.
          We made two of each on this run but plan to make more in the near future and will be selling them individually if people want. Currently, the same cover is used on both sides of the engine.
          I am talking with a molder about possibly molding some valve covers from the same composite material that intakes, TB and other valve covers are made from. Even though they can mold them in various colors, they just won't have the bling of a billet part.
          '79 MGB - LZ9 - T5
          • CNCguy
            Bisong eater :P
            • 1017
            Matt... I have thrown around the idea of a bolt-in electric water pump but it is further down the list as of now. Too many projects to do.
            '79 MGB - LZ9 - T5
            • onefastV6
              • Sep 2005
              • 880
              Looking good as always, any ETA on the single roller sets?
              I have a high compression project that I will be working on, and would love to use a singe roller setup.
              2000 Grand Am GT
              2011 Chevy Impala
              • Nick-G
                11's or Bust...
                • Feb 2008
                • 224
                Great Job! Its always nice to see more products made available for our engines.
                BUILT Turbo 3400/4t65e-HD powered Grand AM in the making.
                • kflo 93 gt
                  Bangin' Gears
                  • Nov 2003
                  • 238
                  Wowzers!!!! I'm going to want just 1 of the finned valve covers lol, and also the single roller timing set will be on my list.
                  I love the new work!
                  14.60 @ 96.33 for now...
                  • loner666
                    • Oct 2006
                    • 435
                    Very nice stuff as always. I may be interested in an electric water pump depending on when you get around to it. How about better fuel rails? I only know of stock ones being available right now but maybe Im wrong?
                    Best 1/4mile ET - 12.9
                    Best 1/4mile MPH - 111
                    1997 Ford Ranger Splash
                    Daily Driver
                    • Joseph Upson
                      CNC take a look at this adjustable fuel pressure regulator that I'm going to replace my current modified OE regulator with. It has a bypass that makes it perfect for use with the returnless fuel rail on the new engines as well as an extra port to mount a pressure gauge on.
                      Read over the pdf file with the specifics on it at the bottom of the page.
                      Perhaps you can fabricate some adjustable high flow fuel rails to accept the standard length and shorty style fuel injectors, or make and adaptor for the early style rail that makes it possible to use it with both injector types. Since it has one threaded end the other can be blocked off to make it work with the regulator.
                      • CNCguy
                        Bisong eater :P
                        • 1017
                        I like the Mallory unit and am using one on the MinusOne with the GEN-III AN-6 adapters. This should flow almost twice as much as a stock setup since both rails being fed fuel. It is hard to see the line routing in the pic but the AFPR has a fuel feed line from the pump, a return line to the tank and two lines feeding the fuel rails. I chose to use hard lines since my regulator is mounted to engine but flexible lines could be used if needed.
                        The newer GM returnless fuel rails aren't as friendly to modifications since they appear to be a brazed assembly with a small single input line.
                        I will look into some adapters for the shorter injectors.
                        BTW... Joseph, the spacers went out yesterday via USPS.
                        '79 MGB - LZ9 - T5
                          2) Does this mean no cam sensor, which also means no OBD1."5" cars either? Hmm I guess that doesn't matter you can't tune OBD1."5" anyways so you'd be going MS or whatever anyways LOL. I think you could probably run OBD2 if you just disabled the SFI error codes as that's all the cam sensor is used for. It will default to MPFI mode, but not sure how well it can run like that.
                          3) Will it fit under stock front coolant pipe on FWD? Click my sig for larger image/site. Do they have the baffles like stock on the inside that keeps the oil from splashing near the PCV and vent hole?
                          Will that single roller chain be stronger than stock link style?
                          • montess408
                            • May 2006
                            • 391
                            so that means we could use a 3400 cam and timing cover on the 3900 motor ?
                            if so i can't wait for this !
                            oh and i got to find me a 3900!!!
                            • Alxsmt
                              that one guy
                              • Feb 2007
                              • 725
                              screw everything else, i wanna know more about the ITBs!!
