Fancy boat anchors
    Live life 3.7mi at a time
    • 4555
    Fancy boat anchors
    • 13531
    Do those flow 290 cfm?
    • loner666
      • Oct 2006
      • 435
      Are mine going to look like that when your done John? btw, you can start on them when you get a chance. Looks like Ill be pulling apart as soon as I get a chance
      Best 1/4mile ET - 12.9
      Best 1/4mile MPH - 111
      1997 Ford Ranger Splash
      Daily Driver
      • 34blazer
        • Sep 2007
        • 341
        did you cut the radius down around the head bolt bosses? looks pretty straight
        '86 Grand National
          • 4555
          Made them less of a "bump" and smoothed them, raised the roof a little after the port entrance, sharpened the port dividers, smoothed the short side from the almost 90* bend right at the valve, and smoothed out the lumpy bowls.
          I'll have to say the sand casting back then were extremely poor.
          Ben, I'll be happy with 140-150cfm but you will be the first to know when I send one to you
          • 34blazer
            • Sep 2007
            • 341
            in for some flow numbers.
            '86 Grand National
              • 4555
              We can split the shipping on these heavy chunks of iron
              Naw actually I'm doing a repeat job and sending one to Ben. Don't expect it too soon, I have a few things that need done 1st. Anything is better than 127cfm
              • geoffinbc
                Iron Head Enthusiast
                • 5831
                I just finished doing the same work. The exhaust valve bowls on the end 2 ports hand nasty steps in them. I smoothed every thing out and gasket matched the ports. If you have an intake, take a tape measure to the ports. My TBI intake runners are 3/16" shorter in height than the ports in the head. So when I get the engine back from the machine shop I will do some serious port matching on the intake.
