Originally posted by robertisaar
View Post
Custom Intake Manifold
I think you just described GM upper management.-60v6's 2nd Jon M.
I am thinking that what would happen is that the MAF will adjust the injectors to whatever the airflow is through the TB and the Carb will put in the correct air fuel mixture, so combined they will be correct, the computer may even fine tune the injector quanity to make up for any inconsistant carb mixture. Larry
IMO, if you did that, it would be better just to do it all through the injectors due to much better atomization, just use the TB for moving more air, if it can actually do so.
Was searching around for custom manifold threads and found this through the google search engine
http://www.60degreev6.com/forum/show...highlight=3500
Interesting yes!! It actually has to be pretty damn close to fitting under a stock hood, but I can't figure out what supercharger it is!! Too short to be either an m62 or even an m45, unless its a custom case, which it very well could be from gm.......
Very similar to my design except plate will be 2 inches thick and incorporate an intercooler......
On a side note, if it is off of the aztek pace car, it could be from the same motor where my doug thorley headers are coming from....Last edited by kwhauck; 03-04-2011, 11:54 PM.
most likely an m90 from a tbird or 3.8. They are the most common and cheapest SC afaik, I plan to get two of them eventually......
WAAAYYY to short to be an M90.....Originally posted by 2.8/3400 1985 Camaro View Postmost likely an m90 from a tbird or 3.8. They are the most common and cheapest SC afaik, I plan to get two of them eventually......
Its an M62. And it would work just fine under the hood of an Aztek/Rendezvous, and probably the vans as well, but no way it would even be close to clearing a hood on a car. Most care have ~1-1.5" between the top of the plenum and the bottom of the hood. The plenum has a ~1/2" mounting plate welded to it, and then the SC is ~4.5" tall, so it would stick out at least 3.5".-Brad-
Too tall to be an m62, the measurement in the picture shows like 4" and an m62 is 4.9" Maybe his picture is just misleading. I know on the alero, I measured 3 5/8" between the hood and the top of the manifold. This is with the engine covering so you could maybe squeeze another 1/2" or 1" which assuming his measurments are off and really it is 4.9" then yes it would sickout of the hood 2-3"Originally posted by bszopi View PostIts an M62. And it would work just fine under the hood of an Aztek/Rendezvous, and probably the vans as well, but no way it would even be close to clearing a hood on a car. Most care have ~1-1.5" between the top of the plenum and the bottom of the hood. The plenum has a ~1/2" mounting plate welded to it, and then the SC is ~4.5" tall, so it would stick out at least 3.5".
it is definetly from a t-bird, and that BOV is pretty clever use of the stock intake opening.
it's an M62, not a very good design though, to tall and bulky..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
nope, tbird is a 3rd gen m90 which is 5.42 inches tall....Originally posted by bob442 View Postit is definetly from a t-bird, and that BOV is pretty clever use of the stock intake opening.
too tall still, m62 is 4.9, the pics show 4.5in....Originally posted by ericjon262 View Posthttp://www.capa.com.au/eaton_m62data.htm
it's an M62, not a very good design though, to tall and bulky...Last edited by kwhauck; 03-05-2011, 05:51 PM.
Originally posted by kwhauck View Postnope, tbird is a 3rd gen m90 which is 5.42 inches tall....
the pic isn't straight on, it's at an angle so it looks shorter than it is."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
true, and it does look like the aztek pace car setup, which was an m62, 2001 so probably a series 4 m62..Originally posted by ericjon262 View Postthe pic isn't straight on, it's at an angle so it looks shorter than it is.
Originally posted by trotterlg View PostAnyone ever tried this? Machine a pad on the top of the upper intake manifold, cut a couple of holes in it to match up with a 2 barrel carb. Run the carb totally closed until you run out of TB opening, then start opening up the carb, sort of like flipping the switch on a Nitrous system. Upper intakes are dirt cheap and so are 2 barrel carbs. Larry
Unless the engine is pulling a vacuum at WOT the stock TB is flowing plenty to support the flow needs of the top end. Your modification would do absolutely nothing for performance.
