Custom Intake Manifold
  • WrathOfSocrus
    • Jan 2008
    • 318
    #61
    It's a nice design but if you look at the flat bottom you can tell it has more than 60 degrees between cylinder banks. The flat end on our valley is roughly half of that one. It's still FAR superior to bolting on top of the UIM but I don't see how it can fit under a stock hood with that design.
    • kwhauck
      Olds Sleeper
      • Aug 2006
      • 379
      #62
      This I know, although I think that with my cowl hood I could clear the charger (on top of UIM) under my hood, but not the driveshaft and pulley.
      Found this today and started tinkering around in psychology class lol.........
      http://www.emachineshop.com/
      Pretty easy to use and manipulate. I think I will use them for intake flanges and work with plate aluminum and a router after that. Probably use some material from RMR as well..
      • gar70614
        • Oct 2008
        • 330
        #63
        wat if u put a lim in a bridgeport mill and milled the hell out of it?
        • kwhauck
          Olds Sleeper
          • Aug 2006
          • 379
          #64
          bump bump...............I mostly have been doing a lot of research/reading/head banging when I have the spare time. Anybody else thought about this?
            Please tell me those aren't headbolts holding your engine to the stand.. that's an accident waiting to happen.
            i don't see why you couldn't do something like this with a gen3 lower intake..
            • kwhauck
              Olds Sleeper
              • Aug 2006
              • 379
              #66
              interesting, are there more pictures of that manifold? or a build thread?
              I would be concerned with height with that type of manifold, it is possible though.....
                It was in my archive of random 60v6 stuff, i don't remember where it came from. it looks like there is plenty of room to lower down the flange though.
                • CNCguy
                  Bisong eater :P
                  • Dec 2003
                  • 1017
                  #68
                  I toyed around with the idea of a custom intake to mount a M90 from a Super Coupe. Was looking at mounting it a little lower and moving the injectors towards the valves. This would have required new valve covers to clear the injectors. The total height was going to be around 1.5" taller than a 3400 UIM.
                  Dave... isn't that the intake Ortie666 made for his Acadia (Chevette)? What ever happened to him?
                  MinusOne - 3100 - 4T60E
                  '79 MGB - LZ9 - T5
                  http://www.tcemotorsports.com
                  • kwhauck
                    Olds Sleeper
                    • Aug 2006
                    • 379
                    #69
                    yes it could be lowered, i just worry about having enough plenum volume to keep good air pressure where I don't lean out a cylinder. I suppose some internal velocity stacks in the plenum could help.
                    • neo71665
                      its this big
                      • Oct 2005
                      • 361
                      #70
                      Yes, yes I have.
                      I have the lower intake off a 3.4 f-body that I wanted t try to mill out then mill a flange to bolt a blower to it. I might have even had a thread on here somewhere asking about it. I was basically told roots blowers suck and don't do it. Running a TBI I'd rather do a roots setup. Unfortunally I've gave up on high powered 60 degrees and just dropped a v8 in my 4x4 blazer. The 3.4 wasn't making the power or torque to keep up with the tires I plan on putting on it after the solid front axle swap. I've since gotten a 2wd sonoma to put the 3.4 in.
                      87 3.4 4x4 blazer
                      • bob442
                        Show Me Your KITS!
                        • Nov 2008
                        • 1305
                        #71
                        i forgot about this concept. now that i got the intakes off my car, i wonder if i should get 3 aluminum plates and start to build a intake. i got Alllllllllllllll winter..............
                        EDIT: i suppous theres going to be a small problem with the snout and power steering pump...
                        So if relocating the power steering pump was done, this idea is very hard to play with, very little room, that this sucker is wide. theres about 1-2" to bring the blower higher, so theres not much room for runner volume. BTW the M90 was out of a burnt wreck, bought it as a mock up piece. someone would also need a shorter snout.
                        • kwhauck
                          Olds Sleeper
                          • Aug 2006
                          • 379
                          #72
                          That thing is so big casewise compared to my whipple!! I really don't see the power steering as being a big problem. I have looked at several different options. I right now, am considering the consequences of runner length and plenum volume, since I am almost certainly stuck with a v-shaped plenum with short (1-2") runners leading into that. I can move up at least 2 inches higher than stock thanks to my cowl hood, however I am not sure if I do that if the two piece snout and pulley will clear. I suppose I could always mold a small fiberglass speed bump to the side of my cowl where the pulley would be.
                          • bob442
                            Show Me Your KITS!
                            • Nov 2008
                            • 1305
                            #73
                            got a picture of your intake?
                            • kwhauck
                              Olds Sleeper
                              • Aug 2006
                              • 379
                              #74
                              You mean my imaginary one? I'm as far along as you are...lol
                              • kwhauck
                                Olds Sleeper
                                • Aug 2006
                                • 379
                                #75
                                oh and I posted some pics on the last page, that is as far along as I am...
