cam shaft swap help
  • Rootie524
    • Feb 2010
    • 543
    #106
    i've setting up dyno time this monday at a local dyno that can tune it for me. im excited about that.
    and quick side note..i can do a 3500 top end swap (LIM and UIM) on my 3100 right? if i get the ported 3500 intake manifolds how much better is it than ports 3100 manifolds?
      • 13525
      #107
      You can only use the upper intake. I hope they are doing a VE tune first before they go for the hp.
      • Rootie524
        • Feb 2010
        • 543
        #108
        well ill be sure to tell them to do VE and then go for the hp numbers.
        • Rootie524
          • Feb 2010
          • 543
          #109
          oh and i can definitely feel the power band of the new cam. 1k-3k it's pretty slow then you start to feel it growing in power..its quite nice.
          only concern is..i lost alittle low end power..no problem..but if i need doing mods..wont that make low end power horrible. like if i power the heads, get headers, get the 3500 vavles, ported 3100 LIM and ported 3500 UIM with 65mm TB..won't that make low end horrible?!
          how do i keep low end decent while having awesome high end? i hope you understand what im saying
            Tuning will fix most of that.
            • 60dgrzbelow0
              "Yes... I AM IRONMAN..."
              • Mar 2009
              • 1344
              #111
              Rootie.... Unless you have already covered this... Why not ask Ben (WOT-Tech) if he has some or all of the performance or modified components you are thinking about adding to your engine? Chances are... he either has them...or knows of a member who does...
                • 13525
                #112
                Tuning for sure. Can you post the cam specs again? My ported heads will improve power all over because I focus on flow with velocity. The cam is a huge impact on powerband though.
                • Rootie524
                  • Feb 2010
                  • 543
                  #113
                  i know 60dgrzbelow0 that's where i plan on getting all my ported stuff from..like heads and LIM and UIM and TB. and idk if you have headers yet that will work on the N-body.
                  heres a pic of the cam spec sheet:
                    • 13525
                    #114
                    The low end power should be close to stock. Past 4k, there is kore power with the new cam and that is probably why it needs tuning there and doesn't feel as powerful right now.
                    • Rootie524
                      • Feb 2010
                      • 543
                      #115
                      so is that still under VE? like what should i tell the dyno people or will they know what to do
                        • 13525
                        #116
                        Anyone that has a dyno and sells tuning service should know what they are doing, but its not always the case. VE tune. Make sure they have a load bearing dyno so that they can hold a speed and record steady state conditions. Tuning for power is last.
                        • Rootie524
                          • Feb 2010
                          • 543
                          #117
                          and when you tune..it's permanent..right? its not like i disconnect the battery and its gone..dumb questions but im just making sure.
                            Yes, it's "burned into" the computer at that point once it's written to the PCM, until the next time it's overwritten.
                            • Rootie524
                              • Feb 2010
                              • 543
                              #119
                              my car now eats through gas and doesnt give me much performance. im guessing that the VE that your all talking about.
                              i need a tune..but pretty soon in the future im porting the heads, new valves, ported LIM and UIM and bigger injectors. so why would i get it tuned now if im going to get it tuned in the future. where im going is 100/hr dyno & tuning..im guessing about 2 solid hours. one for VE then one for power. So i dont want to do that twice.
                              is it safe to drive the car as it is now?
                              • mfuller
                                Mr. Common Sense
                                • Nov 2003
                                • 374
                                #120
                                Your cam specs are pretty close to mine (.323/.337 lobe lift, 212/220 degrees duration @ .050"). You really should get at least a VE tune before putting a bunch of miles on it. Ideally, get all of your hard part upgrades done and tune immediately - but having a cam really throws things off and you should not wait.
                                Matt
