lx5 65 mm throttle body
  • rayruner
    • Apr 2010
    • 40
    can someone tell me if there is an advantage to using the 65 mm throttle body on my blown 02 3100 malibu pumping 7 lbs. seeing as i'm forcing air into my stock throttle body now. thanks
  • trewyn15
    • Oct 2010
    • 178
    there would be a little better throttle response possibly. I'd say go for it!
    2004 Monte Carlo LS
    Build Thread
    Youtube Channel
    ^Add and Sub & I'll Return The Favor^
    • chris_gt_74
      • Oct 2011
      • 61
      I'm not boosted but I put an lx5 throttle on my 3400 and noticed a pretty good improvement.
      • AleroB888
        • Nov 2009
        • 249
        Yes, go ahead and do it.
        While we're at it, can anyone tell me if the LX5 mounting bolt pattern is the same as this one? This is what I use now, but I would like to try the 65 mm.
        I need to make a mounting flange, and was hoping one flange could accept both. If not, a pattern of the LX5 65 mm's outlet side would be helpful.
          • 13522
          What TB is that?
          • AleroB888
            • Nov 2009
            • 249
            What TB is that?
            From a 4.3 Chevy 6 Cyl. The trouble is, it has to be modified to work. I had to use a different model's shaft with cable crank lever and plate, and had to rotate the TPS. I'd just as soon use the LX5 if I'm going to start from scratch, I assume that it needs no mods, except the cable bracket. And hopefully, it is readily available
            edit: the one in the pic is a spare I just picked up on Ebay, not the one I was actually using.
            • chris_gt_74
              • Oct 2011
              • 61
              There is no off the shelf bracket I'm aware of other than the stock lx5 bracket which likely not work without modding and still may not work. That bracket is also thick as hell and big. I just put one on my 3400 and had to pick up an adapter from Ben and I had to modify my stock 3400 bracket which was a pain.
              • AleroB888
                • Nov 2009
                • 249
                That's not a problem, I already got a "universal " modded stock bracket Click image for larger version
                • chris_gt_74
                  • Oct 2011
                  • 61
                  Well then you maybe fine depending if the throttle body will match up. It's a 3 bolt pattern but I'm not sure if the holes are in the same place. One off center top and 2 bottom.
                  • Mars
                    • Apr 2004
                    • 826
                    4300 / 4800 / 5300 / LSX TB's are all the same. 75mm, but the smaller engine TB's have a half-moon restrictor plate in them..
                    Haha, when I bought my 4.3 TB I cam up with a little saying :
                    LS1 TB : 120$
                    4300 TB : 24$ shipped (ebay)
                    Knowing that they are the same part : Priceless.
                    haha.
