3500 hp
  • Lilchief
    • 87
    3500 hp
    Just wanting to get an idea of several senerios. How hp/tq could you get with a stock 3500 non vvt and a single cam change? Or cam change and bigger TB, headers? And lastly Head work, street/strip mild porting bigger springs streetable big cam bigger TB headers port matching ?
    Thanks Rick
  • mfuller
    Mr. Common Sense
    • Nov 2003
    • 374
    It is pretty well documented that a stock 3500 with a big cam mild porting and headers can make solid 300 hp (see Superdave's old 3500 Cavy). But you need to remember that the potential power from a cam change can be heavily dependent on supporting mods; just throwing a large cam in an otherwise stock engine can actually reduce power.
    Sent from my iPhone using Tapatalk
    Matt
    • mfuller
      Mr. Common Sense
      • Nov 2003
      • 374
      I forgot to add that proper tuning is just as if not more important than the hard parts you throw at a motor.
      Matt
        • 13533
        stock engine. street cam 12 hp, street/strip cam 25 hp, strip cam 31 hp, race cam 40hp.
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          real dyno numbers or desktop dyno?
            Considering what i've gotten out of stock 3500's on the dyno, Ben is about right. Supporting mods will play a huge role though.
            my 5 speed Cavalier put down 275 to the wheels with a ported top end, custom ground cam and longtubes. That's a little over 300 @ the crank. Same engine with a little more work and ITB's put down 263 WHP with an auto trans, that's roughly 330 HP on a rough tune.
            • robert 1980
              • Aug 2009
              • 302
              Stop talking before i buy a 3500=)
              • NateD4
                • Mar 2011
                • 576
                I wonder what they do if you wind them to 8500 RPM
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  Probably throw a rod....
                    Mine didn't... /oops
                    stock rods are good for 7K ish, i push mine there often.
                    • NateD4
                      • Mar 2011
                      • 576
                      I think I can get to 8K without losing a rod.
                        Go for it.. lol
                          Don't forget to record it.
