lx9 windage tray's anyone?
  • grnrdragon
    • Apr 2010
    • 46
    anyone found a oil pan and a lifter valley windage tray? also has someone had luck putting a 3.4's crank scrapper on the lx9 (I one longer have the crank reluctor wheel)?
    • 13499
    There are no scrapers that fit the 3500. They might be able to make one if they have a block/crank/oil pan. The block is notched for the rods to clear and there is no room with the oil pan on for the scraper to go (when they sent me materials to make a template).
    • grnrdragon
      • Apr 2010
      • 46
      so what of valley and oil pan tray's?
        • 13499
        what about them? They came stock with that stuff already.
        • grnrdragon
          • Apr 2010
          • 46
          I'm sorry the 2 lx9's I've gone through had nothing but the plastic lifter anti-rotation guilds underneath the intake.
            • 13499
            The windage tray goes in the oil pan on the mains.
            • grnrdragon
              • Apr 2010
              • 46
              so dam valley tray. holly cow.
              • grnrdragon
                • Apr 2010
                • 46
                so I take it that no body knows about ANY lifter valley tray. thought someone would have found something or someone that makes one. figured it would help keep the intake temps down?
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  I don't think any of our motors came with a valley tray, but it shouldn't be too hard to fab up.
                  • grnrdragon
                    • Apr 2010
                    • 46
                    I figured as much. no after market ones?
                    • ericjon262
                      build it.
                      • Jan 2010
                      • 2218
                      not that I've ever seen, I doubt anyone will either, no real demand, I think you're the first to ever ask about one.
                      • grnrdragon
                        • Apr 2010
                        • 46
                        ok. so what about the crank scraper? I've seen them from sale for the 3400. wouldn,t it work on the lx9 with some mods done?
                        • geoffinbc
                          Iron Head Enthusiast
                          • 5831
                          A valley tray wouldn't be a bad idea. It would be easy to fabricate and could just lay in the valley with a slight friction fit. Or you could have light weight springs on the top that would contact the bottom of the intake so put some pressure on it. Some Fords and Dodges along with Pontiac all used a valley tray. Some to seal and some just as a splash shield under the manifold.
                          • grnrdragon
                            • Apr 2010
                            • 46
                            do you think it would be safe enough to use the 2 middle intake bolts (the ones that don't have intake gasket close) to anchor to?
                              Why re-invent the wheel? Make it similar to this with the curved black spring steel going under the heads somewhere.
