High Compression 3400/3500 NA build
  • 02GT_Skyhigh
    • Jun 2010
    • 88
    My engine now has 194,xxx miles and I believe the timing chain broke but whatever, this build is on. I usually garage the car here when its gets cold and theres snow on the ground (SLC, Utah). Just gonna pull the motor and throw the car cover on that beech for the time being...
    Should be fun..
    Plan is 3.4L DOHC flat-top pistons 0.020" over.
    Some crazy cam that Will make it happen.
    Other mods will be announced as they happen
    Transmission work is still a few months out.
    Have a machine shop lined up to get the work done on the short block.
    Ben is going to assist me with deciding on cam specs to make this thing come alive.
    What Ive ordered so far:
    -Crank scraper
    -ARP Rod bolts
    -Clevite Rod Bearings
    -Cam Bearings
    -94-99 Timing Chain
    -Guide for Chain
    Pics will be up of the old motor coming out. Gotta find out everything that needs to be disconnected to get the motor our. Everyone loves pics damnit!
    This build is going to happen over the next 4 months, be patient.
    2002 GAGT
    - Street/Strip 3500 Heads - WOT-Tech Comp 3500 LIM - K&N Drop In - Magnaflow Cat and Muffler
    - Eibach Lowering Springs - Bridgestone Potenza 225/35/r16 - Drilled and Slotted Rotors - Ceramic Pads - KYB GR-2's
    - Big 3 Electrical Upgrade - Kicker SX650.1 Monoblock - Kicker CVX12"D4 Sub
    - Ported Box @ 1.88^ft to 34hZ - Alpine CDA-9884 - Cadence 6.5" Component's
    http://www.cardomain.com/ride/391881...am-gt-sedan-4d
  • 02GT_Skyhigh
    • Jun 2010
    • 88
    Are these the flat top pistons from 93-95'?
    http://www.ebay.com/itm/93-95-Chevro...4130f8&vxp=mtr
    2002 GAGT
      • 13517
      No, they will have valve relief cutouts in them. The camaro is an iron head, and you can use those pistons with .030 thick head gaskets for high compression too.
      3.4 DOHC pistons (91-95) with 3500 heads will give you 14.4, if you use cometic gaskets that are made for the bore, and .040" thick.
      3.4 Camaro pistons with 3500 heads will give you 12.8:1, if you use cometic gaskets that are made for the bore and .030" thick.
      Both of these situations are with .040" quench.
      • 02GT_Skyhigh
        • Jun 2010
        • 88
        Progress today. No problems, ready to go! We pulled the whole harness just cause thought it would be easier.
        Cut the exhaust right at the flex.
        Went really smooth, took about 3 hours.
        Got everything disconnected
        Little friendly help from a good friend.
        And the help of my grandpas tractor
        Ready for teardown
        2002 GAGT
        • 02GT_Skyhigh
          • Jun 2010
          • 88
          Bent valves, one bent push-rod.
          Gonna need new valves. My friend is going to help me put in the new vales and were going to lap them. Im not worried about the push-rods cause ill get new ones with the cam
          Parts Box i made lol
          2002 GAGT
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            yeah, I'd say that's bent!
            • 02GT_Skyhigh
              • Jun 2010
              • 88
              This is the plan.
              Built 4T45, LSD, and 2500 stall converter
              Got a referral to a trans guy
              93-95 Pistons (11.5:1 with 0.040" gaskets)
              S&S Headers
              And im going to put PAC springs on the heads to run a bigger cam. For max lopeage
              Few snaps n shiz of the timing chain when I took the timing cover off.
              and pistons are here!
              2002 GAGT
              • 02GT_Skyhigh
                • Jun 2010
                • 88
                Got this from Ben the other day. With 1.6 rockers the gross lift is going to be 0.576"
                Edit: And I have a set of coated S&S headers on the way also..
                Transmission is going out to be rebuilt in the next week or so.
                2002 GAGT
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  lol, what timing chain??? :P
                  • Blacktree
                    '87 Fiero SE
                    • Dec 2006
                    • 48
                    Hmm... looks pretty ouchy. I'm kinda surprised one of the valves hit the piston.
                    Speaking of valves, can you tell me the valve dimensions (overall diameter and total length)?
                    • 02GT_Skyhigh
                      • Jun 2010
                      • 88
                      Heads are done with the PAC springs.
                      Block is bored
                      ARP studs are on the rods and the rods were reconditioned
                      Crank was turned, all the surfaces are baby ass smooth
                      2002 GAGT
                      • kego
                        • Jul 2014
                        • 13
                        give me progress photos or give me death 0.0 lol
                        • ericjon262
                          build it.
                          • Jan 2010
                          • 2218
                          I spy a BBC head...
                          • 02GT_Skyhigh
                            • Jun 2010
                            • 88
                            Got the fly cuts done, did this about 3 weeks ago. went 0.060" into the pistons. I cleaned them up after pics with a sandpaper wheel. nice n smooth.
                            2002 GAGT
                            • ericjon262
                              build it.
                              • Jan 2010
                              • 2218
                              I would polish/debur the tops of those pistons.
